    Apr 2005
    Manchester England
    43
    332
    dip switches on hitachi twin split
    hi guys
    I recently installed a hitachi twin split system in a house, 2 ducted indoors in the loft feeding 2 bedrooms with seperate controllers.
    i test ran on heat and cool one of the bedroom units, the other i could not test due to the bedroom walls being painted and they did not want dust kicking around the bedroom and messin the walls up
    Outdoor model no: RAS 2HVRN1
    my question is: do i need to address these units in any way to make one a master and one a slave and also will these units run okay being in 2 seperate rooms on two seperate controllers?
    thanks
    lee
    Feb 2005
    United Kingdom
    56
    Re: dip switches on hitachi twin split
    You cant twin with a RAS 2 HVRN1. You can only twin with a RAS 3 and above.
    The only hope you have is to dip the outdoor to tell it that it is a size 3 and also do the same on the indoors to tell them they are size 1.5.
    What indoors have you used? I am assuming that they are RPI-1 but I fear they may be something else.
    The electrical panels on the indoor and outdoor have the dipswitch settings. You need to be looking for DSW3.
    Who sold you this system?
    Feb 2005
    United Kingdom
    56
    Sorry - one other thing also. You cant control these units individually. It is not a 2-pipe VRF nor is it a multi. Hitachi do supply an IVX 3HP model which will allow you to do individual control. You may be able to get away with master and slave but it is pointless.
    Apr 2005
    Manchester England
    43
    332
    hi there
    I have got mixed up with the split system i also installed.
    the model number is RAS 3 HVRNME
    the main thing i would like to know is dip switch settings and also is there a problem with this having two remotes and being in 2 different rooms.
    if bedroom 1 is calling for cooling but bedroom 2 is off will the gas still go to the OFF unit therefore freezin the coil??
    thanks lee
  1. fujitsu AOY18LMAK2 twin split
    By roger the chill in forum Trouble Shooting
    Last Post: 14-07-2009, 11:44 PM
  2. Hitachi split timer LED 10 flash
    By paul_h in forum Air Conditioning
    Last Post: 12-02-2009, 12:32 PM
  3. Sensible Heat Factor / capacity of Inverter split Systems at part load?
    By Greengrocer in forum Technical Speculations
    Last Post: 09-02-2009, 04:57 PM
  4. hitachi g5 twin slpit
    By tait71 in forum Air Conditioning
    Last Post: 16-08-2007, 10:25 PM
  5. Daikin twin split
    By Lippygit in forum Trouble Shooting
    Last Post: 28-07-2007, 06:28 PM
