Results 1 to 2 of 2
    dennyf's Avatar
    dennyf Guest
    Adding oil back after recovery
    After recovering the charge from a 5 ton residential unit how much oil is removed? When I go to recharge with virgin R-22, should I be adding oil to replenish the oil in the refrigerant that is now in the recovery tank?
    11,025
    Re: Adding oil back after recovery
    I would think that very little oil was removed unless you had an access port below the oil level.
    Mind you, I could be wrong.
  1. [Autocascade] Only a project ATM
    By before in forum CPU Overclockers
    Last Post: 07-05-2009, 11:13 AM
  2. Why Bikers Don't Wave Back...
    By Brian_UK in forum Chit Chat & Service Stories
    Last Post: 16-04-2008, 11:51 PM
  3. complete System Recovery
    By absolute-zero in forum Computers & the Internet
    Last Post: 20-01-2008, 06:03 PM
  4. Freezing back to comp (mitsu elec)
    By expat in forum Air Conditioning
    Last Post: 29-07-2007, 11:14 PM
  5. Low back pressure compressor application
    By Abe in forum Technical Discussions
    Last Post: 31-07-2001, 11:43 PM
