Thread: Identifying Energy Losses
09-10-2009, 10:46 AM #1
Hi..
Please help me in identifying the energy losses in the centralised air conditioning system.
I need to reduce the heat load of the total plant, either by modifying the layout or installing new applications.
I had identified air infiltration as on of the losses..please help me in finding other losses
09-10-2009, 07:33 PM #2
Re: Identifying Energy Losses
Unfortunately we cannot see the plant or building that you are working on so it is a little difficult for us.
09-10-2009, 10:35 PM #3
I find that getting up in the morning is a total energy loss..
Karl
10-10-2009, 01:02 AM #4
Hi Arun.
In the past on a particular site where the client was extremely mean with money, I had a huge saving in power consumption by reprograming the control system to totally air purge multi storey high rise at night when ambient dropped at around 3.00 am. Full fresh supply and max extract exhaust, the effect was chilling each flow slab in turn a negative heat sink, saved around 15 % power during peak summer conditions.
Problem if night ambients temps do not drop. Generally the ambient changes close to sun up. Barometric changes etc.,
10-10-2009, 09:38 AM #5
Hello.
What heat loads are - as Brian UK poined out?
Are windows prevented from letting in much of the sun radiation?
Energy Conservation
By US Iceman in forum Technical SpeculationsReplies: 20Last Post: 20-07-2010, 10:52 AM -
high pressure refrigerant using heat energy
By nadam54321 in forum Technical SpeculationsReplies: 4Last Post: 19-08-2009, 04:07 PM -
Energy From Oil
By DavidAdam in forum Chit Chat & Service StoriesReplies: 11Last Post: 02-07-2009, 12:40 AM -
Thermal Efficiency of Refrigeration System
By hussain316 in forum Refrigeration BooksReplies: 5Last Post: 31-07-2007, 08:59 PM -
A question about energy efficiency rating in Europe
By pcdata76 in forum FundamentalsReplies: 1Last Post: 22-05-2006, 10:17 AM
