Results 1 to 11 of 11
    Oct 2009
    Canada
    35
    7
    Question Wondering about TX valves.
    Hey I know this may be a stupid question but I just got out of school and I have a guy wanting me to help him with a side project at his house for a cooler in his garage..he has everything he needs but a TX Valve, the system will run off R-22 so do I just need to get any compatible TX Valve or is it more specific.
    Split Croatia
    57
    6,151
    36
    Re: Wondering about TX valves.
    We need to know compressor make and model # and what is cooler working temperature.
    Oct 2009
    Canada
    35
    7
    I dont know the exact model number it is a tecumseh condensing unit and we'll be running it about 35-40..This is also just a little side job doesn't need to be fancy he just cuts a little meat in his garage and just wants something thrown together that will run.
    Split Croatia
    57
    6,151
    36
    Quote Originally Posted by ci_1612 View Post
    We need to know compressor (evaporator) capacity, saturation temperatures/pressures to select correct TXV.
    Oct 2009
    Canada
    35
    7
    Also this isnt the case with this job as all components came with the system except the TX Valve but would it be possible to fun a system with basically just the compressor evap condensor and TXV..meaning withought the drier and LLSV and stuff..Like I said I'm just out of school and just being curious.
    Feb 2008
    adelaide sth.oz
    1,015
    listen to what nike says otherwise you can end up with slimy or dry meat
    Split Croatia
    57
    6,151
    36
    Filter dryer is must , otherwise TXV could stuck or clog with dirt and moisture.
    LLSV could be omitted if system have accumulator.
    TXV must be matched with evaporator and working conditions, you cannot use just any kind/size TXV.
    Oct 2009
    Canada
    35
    7
    AHB7511AXDXC is the model number and the evap coil is a husmann 95096-c
    Oct 2003
    5,630
    34
    You're just out of school, was that a refrigeration related school you just left at 21 years?
    Split Croatia
    57
    6,151
    36
    Danfoss TEX-2 with oriffice 02!
    Order no:
    1. Valve Body 068Z3209
    2. Orifice Assembly 068-2015
    lebanon
    130
    hi
    may be it comes with orifice&he didnt knew it
  1. Too dependent on Danfoss Valves
    By kelvin_27_84 in forum Industrial
    Last Post: 24-01-2009, 08:33 PM
  2. Stainless steel valves
    By Tycho in forum NH3
    Last Post: 05-11-2008, 02:16 PM
  3. Understanding Balance port TX valves
    By Mobbsy in forum Technical Discussions
    Last Post: 23-07-2008, 04:32 AM
  4. Hinari and how far to open valves
    By stryker in forum Air Conditioning
    Last Post: 14-04-2008, 01:47 AM
  5. dan foss tx valves
    By fuzzy in forum Trouble Shooting
    Last Post: 02-10-2007, 01:11 PM
