Results 1 to 2 of 2
Thread: Grasso rc9
    495
    21
    Grasso rc9
    Hi guys whats the maxium allowable oil pressure ,because i ve stripped a compressor and it has what looks like thrust problem because it has worn away the crank,and i cant see what else can cause this apart from oil pressure from pump pushing it forward on to the drive end bearing housing, any info would be helpful ,thank you
    Somerset
    69
    4,697
    Re: Grasso rc9
    Hi Ghaz.
    The oil regulator (external one) is set to 1.5 bar differential between the suction and displayed gauge Pressure.
    I suspect that the internal oil relief valve may be the culprit though.
    Cheers grizzly
  1. The new Grasso V series reciprocating compressor
    By Sturt in forum New Technologies
    Last Post: 17-11-2009, 09:37 PM
  2. Slide valve wear on Grasso screw after just 54000 Hrs
    By Lodiev in forum Technical Speculations
    Last Post: 14-09-2009, 01:21 PM
  3. Grasso SP2 duo packs
    By aawood1 in forum NH3
    Last Post: 12-06-2009, 10:56 AM
  4. Grasso spares
    By Slush Puppy in forum Industrial Compressors
    Last Post: 23-01-2009, 05:44 PM
  5. KAB S3-900 (Grasso)
    By Gerben in forum Industrial Compressors
    Last Post: 03-12-2008, 07:24 AM
