    Scott Buker's Avatar
    Scott Buker Guest
    Scroll compressor current
    I have a machine condition monitoring system in my plant that can monitor current, vibration, temperature, etc. I'm monitoring current on some 15 hp scroll R404 compressors. The current went up on one of them by 10 to 15%. We changed the compressor to avoid burnout and downtime and the current returned to normal. After 5 weeks is climing again, but with a different waveform. We thought that there may have beeen some acid in the oil, but the test showed none. Any ideas?
    Split Croatia
    6,151
    Re: Scroll compressor current
    Current of motor depend on compression ratio and mechanical efficiency of compressor. If compression ratio is changing then current is also changing.
    Monitoring current without relation with compression ratio doesn't tell you much about compressor motor.
    On the other hand, regular measuring of compressor motor insulation tells you everything about winding state.
    Check this post.
    Aug 2009
    New Zealand
    59
    2,554
    Hi, is this a common system, more than one compressor?
    Possible inbalance in oil return. Oil levels in scroll seem to be more critical. (in my opinion) slight loss indicated, increase in current, no sure how the bearings are fed in these machines.
  1. Copeland Scroll Advanced Protection Problems
    By dwayne in forum Trouble Shooting
    Last Post: 24-09-2010, 06:54 AM
  2. Digital scroll
    By archibaldtuttle in forum Commercial
    Last Post: 06-01-2010, 05:27 PM
  3. Scroll internal bypass
    By Larry2 in forum Heat Pumps
    Last Post: 15-05-2009, 09:23 AM
  4. copeland ZR scroll vs VR scroll
    By Lc_shi in forum Technical Speculations
    Last Post: 03-09-2008, 04:27 PM
  5. Hermetic reciprocating versus hermetic scroll
    By Cofreth in forum Technical Discussions
    Last Post: 19-11-2005, 06:29 PM
