Results 1 to 2 of 2
Thread: Vilter HP compressor
02-10-2009, 05:47 PM #1
Hi guys!
Does anybody here on this forum have any experience with Vilter single screw compressors running on ammonia with approx 45-50 bar high pressure? The compressor will be in a two stage heat pump that can deliver up to 90 deg C water...
If you have any experience at all with Vilter compressors, good or bad, both screw and recips, please reply....
26-06-2010, 08:47 PM #2
Re: Vilter HP compressor
Have you consulted the Vilter factory .They are a wealth of knowledge and usually when there is a unique application such as this,the factory was involved with it's design. Vilter is located in Cudahy.Wisconsin,USA.
Vilter recips are "nicknamed" battleships because they are built tough. The double screw or "howden" designed screw is very rugged. The "gate roter" designed single screw has a lot of moving parts. Both screw machines require a LOT of lube oil to accomplish providing a seal between the lobes
Help needed to find a replacement compressor
By 540itouring in forum DomesticReplies: 19Last Post: 17-04-2010, 02:06 PM -
Thumping noise in the compressor
By Husky250 in forum Air ConditioningReplies: 6Last Post: 16-05-2008, 10:48 PM -
Compressor Knock problem
By AC90 in forum New to REReplies: 10Last Post: 11-05-2008, 04:26 PM -
Compressor Capacity
By engrkate in forum FundamentalsReplies: 15Last Post: 13-10-2006, 12:11 AM -
screw compressor
By vinod in forum Trouble ShootingReplies: 9Last Post: 17-12-2005, 01:46 AM
