    Dirtdobber's Avatar
    Dirtdobber Guest
    Frick Model RXF-101 overhaul?
    I am new to my position and I am trying to learn as much as I can about the industrial refrigeration in our warehouse. We have recently been burned by a dishonest refrigeration tech. Our new tech is saying that our FRICK compressors model RXF-101 are about ready to be overhauled. Can anyone tell me how many run hours we should expect before an overhaul is reccomended. We have had regular PMs done and all our vibration tests have come back satisfactory.
    Any help would be appreciated.
    Somerset
    69
    4,697
    Re: Frick Model RXF-101 overhaul?
    Welcome Dirtdobber.
    I usually steer away from answering posts from disgruntled General Managers.
    It stems from having spent many years in the Cold Store side of refrigeration.
    Where the "Operations" remit is Minimum expenditure. Maximum Profit!
    Which is always in direct conflict with the Engineers Philosophy.
    "Do whatever is necessary to Maintain reliability"!
    Having said that!
    No engineer should need to falsify the required maintenance schedules.
    Nor should any Manager get bitter because the Engineer is telling him.
    About his having to spend money to maintain his equipment.
    And as these are readily available from Frick.
    I have attached a copy below.
    3,358
    Also need to know what conditions compressor runs at and if it changes capacity ( slide valve ) regularily .
    Type of refrigerant
    Weak point in nearly all screws is slide valve wear which can damage rotor tips ( not repairable , easily ) and cause machine to be inneficient
    Older frick info suggests
    40 000 hrs high side operation
    60 000 hrs booster duty
    Also weigh up if it craps itself out of the blue how much will it cost you then . ie do you have any redundantcy .
    Somerset
    69
    4,697
    Type of refrigerant
    As I believe you may say, "Bloody well said".
    Jul 2007
    Czech
    61
    373
    Good to keep the compressor 25 000-30 000 hours is more difficult, 13 bearings. Josef
    MJS's Avatar
    MJS Guest
    Exclamation Re: Frick Model RXF-101 overhaul?
    Strong consideration must be attended to the type of machine and with the RXF the model. These are driven via speed increasers, and in this model tip speeds creep up to 7000!!! RPM.
    The cost of rebuilding these have been prohibitive, and are often resultant in "throw-a-way" models.
    The manuals can be helpful, ie changing filters and oil at recommended intervals, and constant awareness of operating parameters, proper calibration of sensors etc.. on the package.
  1. Frick screw compressor SGC3515 overhaul manual
    By cjlee74 in forum Industrial
    Last Post: 13-10-2010, 08:49 AM
  2. Model to Manufacturer Identification
    By Lucas in forum Air Conditioning
    Last Post: 29-04-2009, 03:25 PM
  3. Frick compressor RXF 101-H
    By PaulZ in forum Industrial Compressors
    Last Post: 19-02-2009, 02:29 AM
  4. Replies: 12
    Last Post: 16-06-2008, 10:06 AM
  5. Fan model for system optimization
    By autt in forum System Optimization
    Last Post: 31-03-2007, 05:34 AM
