Page 2 of 2 FirstFirst 12
Results 51 to 56 of 56
  1. #51
    Apr 2009
    israel
    778
    Re: Water in Refrigerant pipe
    Quote Originally Posted by NoNickName View Post
    I'm reading not just the opposite, but actually it all ends up blaming somebody else. Salvaging such systems is some sort of russian roulette, everybody say: "if the system is evacuated well", or "if the work is done correctly", "if it has been cleaned properly"... but at the end of the day who know if the "if's" are all properly obeyed to.
    I mean, we are all good and trustyworth people, but if it was me, I wouldn't dare recommission a system which was subject to such extensive damage and restoration. What guarantees would I have?
    On one thing I agree: for a refrigeration engineer, this is a FATTY work, and no blame on fail.
    hi there ,it isnt a matter of if ,just do it right and it will work!!
    our job isnt gambling ,it is only a matter of yes and no,when a unit with a water condenser springs a leek u can either fix it or dump the machine ,usually the customer will pay to fix it ,a new machine is much more expensive!!
    we had a quite a few machines with this problem and i can tell u after replacing what needed to be changed and monitoring the unit we have never had repeated failure in these units
    u are correct if the damage is over 50-60% of the units cost ,then fixing becomes a questinable issue.
  2. #52
    Mar 2006
    Merate (LC) - Italy
    2,549
    No, it isn't gambling, but please don't play the game of pretending every refrigeration engineer is a undeflorated virgin.
    Just browse this very same forum: there are refrigeration engineers who charge by sight glass and not by subcooling, or don't even know what subcooling is, or even ask for compatibility of HFC with mineral oil...
  3. #53
    Auckland
    74
    3,357
    38
    NoNickName.
    You and I totally concurr.
  4. #54
    Feb 2008
    adelaide sth.oz
    1,015
    be a bugger if a similar fault occured in a short space of time on the same plant after it all has been replaced.strip,flush,dehydrate and evacuate.whats the problem?
  5. #55
    Apr 2009
    israel
    778
    big big bugger!!!!
  6. #56
    Oct 2009
    Ha Noi, Viet Nam
    5
    Dear all
    I have finish repaired the Hitachi chiller.
    I'm going to change oil and refrigerant tomorrow first time.
    Thank for all yours ideas.
  1. Refrigerant Pipe
    By jteixiera in forum Air Conditioning
    Last Post: 30-03-2009, 07:26 AM
  2. Change my heat pump to water source
    By tinkerer in forum Heat Pumps
    Last Post: 15-11-2008, 07:22 PM
  3. MHI FDCA400HKXRE4 Tech Info Please
    By L.JT in forum Trouble Shooting
    Last Post: 23-08-2008, 11:00 PM
  4. Refrigerant to water heat exchangers
    By sunwind in forum Technical Discussions
    Last Post: 24-06-2008, 01:40 PM
  5. fun quiz
    By Brian23 in forum New to RE
    Last Post: 02-10-2007, 10:18 PM
