Results 1 to 11 of 11
Thread: Refrigeration Capacity
30-09-2009, 03:25 PM #1
Hi guys....can u tell me, how to count the refrigeration capacity for the room that will be installed by the a/c ?
01-10-2009, 06:03 PM #2
- Join Date
- Sep 2009
- Location
- Iran
- Age
- 66
- Posts
- 672
- Blog Entries
- 1
- Rep Power
- 19
Re: Refrigeration Capacity
Could you explain what you main
01-10-2009, 07:49 PM #3
if i wanted to install split a/c to the room, the room that length 5 metre and wide 3 metre.
is there the refrigeration formula for that?
01-10-2009, 11:15 PM #4
- Yes -
Try a search on this forum for 'heat load calculations'.Brian - Newton Abbot, Devon, UK
02-10-2009, 03:24 PM #5
thx....sir.
31-10-2009, 03:32 AM #6
James,
In Air conditioning / Refrigeration while calulating the heat load for any room we should consider L X W X H (Length X Width X Height ). In your case what is height. Height always plays a effective roll in calculations. Only Length and Width is not sufficient.
Satish
India.
31-10-2009, 02:04 PM #7
Also,
What is the room used for,are the people sitting ,dancing etc.
Windows,size and glazing,curtains blinds etc.
Are there machines in the room,printers,copiers computers ,if so you need to find the wattage of them.
Is the room insulated,under trees or in full sun all day etc all these have great bearing on the heat load and the equipment you will need.
24-02-2010, 04:26 AM #8
i was checking out a unit for its cooling capacity.i saw 2500 watts on the evaporator.i have a conversion i create on my phone.1watt=3.41btus.
after converting i got 8525 btus.
the interesting thing is the lines are 1/2''&1/4.the sizes are too large for a 9000 btu unit.i want to know if that wattage is just for the evaporator only or my convertion is wrong.
24-02-2010, 07:24 AM #9
05-03-2010, 04:28 AM #10
Depending on experience as rules of thumb use 12000 btu/h for 400 ft2 (37 m2) of floor space.
05-03-2010, 03:39 PM #11
Measurement of Refrigeration Capacity
By ck10 in forum NH3Replies: 20Last Post: 05-11-2009, 05:25 PM -
refrigeration capacity question
By Katie in forum FundamentalsReplies: 3Last Post: 08-11-2008, 03:14 PM -
COP and Refrigeration Capacity Caculation?
By Uni in forum FundamentalsReplies: 9Last Post: 02-11-2008, 04:17 AM -
How do I increase the capacity of a refrigeration unit?
By Pluto68 in forum Trouble ShootingReplies: 10Last Post: 04-10-2008, 01:21 PM
