Results 1 to 27 of 27
Thread: R12
30-09-2009, 09:58 AM #1
R12
Im working on a small system, it is short of gas and is on r12, im having great trouble getting such a refrigerant, were can I get it?
Steven Crawford
02885548188
30-09-2009, 11:20 AM #2
Re: R12
The short answer is you can't get R12 anymore
It is a CFC and has been banned
There are drop-ins available depending what the system is
30-09-2009, 11:43 AM #3
Re: R12
Dont try to give me this bull****!!! I want R12!!!!
30-09-2009, 12:03 PM #4
Re: R12
You will properly get R12 from china.
30-09-2009, 12:54 PM #5
Re: R12
What you need to do is get yourself a balloon, a long thin tube and some string.
Tie one end of the thin tube to the balloon with the string and let it float up till it gets to the hole in the ozone layer, this is caused by R12 so once the balloon has reached this height, just suck the R12 down with a vacuum cleaner, if you block the exhaust on the vacuum cleaner it will work just like a recovery machine.
ms
30-09-2009, 01:00 PM #6
Re: R12
R12 is an illegal substance not only to sell but to use. You would be better off to recover the remaining R12 for destruction, thoroughly leak test the system and repair all leaks that you find. Carry out an OFN pressure test, evacuate the system and re-charge with R413A or Isceon 49 which is available from HRP and other specialist wholesalers. You may need to reduce the quantity of refrigerant slightly, that is if you know the exact weight of refrigerant that was originally installed and you should get the same performance and pressures as with R12 without having to change the oil.
30-09-2009, 01:55 PM #7
Re: R12
have you got a f-gas certificate to work with refrigerants . ie c&g 2078 or 2079 or a citb eqiv.
30-09-2009, 10:30 PM #8
30-09-2009, 10:36 PM #9
Re: R12
Well he says he is in refrigeration but I have my doubts with his lack of knowledge about R12 and the law.
07-10-2009, 09:59 AM #10
07-10-2009, 10:00 AM #11
07-10-2009, 03:12 PM #12
07-10-2009, 03:52 PM #13
Re: R12
Thanks, I used a Red Henry!!! woops, how long would it take to recover 4Kgs??
07-10-2009, 04:01 PM #14
Re: R12
Ya should always use a green hoover for recovery
07-10-2009, 04:31 PM #15
24-10-2009, 04:06 PM #16
25-11-2009, 07:09 PM #17
Re: R12
Funny managed to find a few tins of striped paint on ebay there! lucky find but very expensive!!
How are ya Paul Tompson? hedged any vans lately????
25-11-2009, 08:56 PM #18
Re: R12
attitude
i think
26-11-2009, 12:04 AM #19
26-11-2009, 09:49 AM #20
Re: R12
Ladies Ladies please.....
Saucer of milk for table two...meeoowww
08-02-2010, 05:44 PM #21
Re: R12
You're in luck !
http://cgi.ebay.co.uk/ws/eBayISAPI.d...m=110491564992
08-02-2010, 06:52 PM #22
09-02-2010, 01:28 PM #23
Re: R12
Questions like this should be ignored as the writer is either taking the you know what, or not & should never be in the trade.
09-02-2010, 05:22 PM #24
24-03-2010, 04:29 PM #25
Re: R12
can i have some R-2 ? pmsl
24-03-2010, 04:48 PM #26
Re: R12
Is that R2D2?
Bedford. Now retired and trying to relax.
08-04-2010, 11:16 AM #27
Re: R12
come to Africa and R12 are readly available but expensive.but why R12 and R134a are there? i think you are becoming a trouble shooter in this trade.leave and do your painting friend.
