    michi's Avatar
    michi Guest
    Samsung RL36EBNS "rd" error
    I have a Samsung RL36EBNS fridge freezer, when I turn it on it start up and then stops "rd" is displayed on the display. After doing a bit of research I found that it has something to do with either the fan motor or the sensor I have taken the cover off and checked; when the fridge/ freezer powers up the fan starts spinning and the little square blade starts spinning (to me that rules out any motor failures, please correct me if I am wrong), so I think I will need to replace the magnetic position sensor?
    If that's the case where can I buy the sensor or does it only come as part of some motor...?
    Thank you for your help and advise.
    Jul 2006
    norfolk
    737
    Re: Samsung RL36EBNS "rd" error
    temp sensor is at fault
    michi's Avatar
    michi Guest
    How can I find out which sensor is at fault, as there are a few in there.
  1. Samsung SR-L3, error code "rd"
    By Rtic in forum Domestic
    Last Post: 16-09-2010, 08:57 PM
Tags for this Thread
