Results 1 to 15 of 15
Hybrid View
28-09-2009, 11:36 AM #1
Which Technilogy to go for my house? (Newbie advice)
Dear experts,
I have zero experience in the refrigeration field and I simply need your technical advice to help me choosing the best refrigeration system technology for my house that I recently started refurbishing.
In my Area, the AC (cooling system) needs to operate max 5 months per year; the question: is it wise overall to go for a VRF system for a house of 240 m2 rather than using the traditional Wall mounted split AC units.
I learned that the VRF system cost is outrageous compared to the traditional wall mounted split AC units (4-5 times more)?
Talking about VRF systems, I heard that Samsung are doing very well; which brand and make do you recommend for a single house residential use (not a building) and you think it is economically good to go for a residential house of 240 square meters compared to the traditional split AC units?
In General, which technology would you recommend in my case? (esthetically, I prefer not to have any wall mounted units installed in the public area of my house, while in the bedrooms, private areas, I don't care)
28-09-2009, 11:53 AM #2
- Join Date
- Sep 2007
- Location
- Split Croatia
- Age
- 57
- Posts
- 6,151
- Blog Entries
- 6
- Rep Power
- 36
Re: Which Technilogy to go for my house? (Newbie advice)
That greatly depend on technical support available in your surrounding.
My advice would be fan coil units and one chiller! Simple to maintain and fix, and yet comfortable as much as VRF systems. Costs are pretty much same or lover than VRF depending on quality of outdoor unit, control features fan coil units and labor costs in your area.
28-09-2009, 12:08 PM #3
Are you talking about the centralized AC system where you have no control over each room refrigeration system? because my mentioned above system is known in my surrounding as the worse refrigeration system from the power consumption point of view which I am interested in taking good care of it.
28-09-2009, 12:42 PM #4
- Join Date
- Sep 2007
- Location
- Split Croatia
- Age
- 57
- Posts
- 6,151
- Blog Entries
- 6
- Rep Power
- 36
As I said, control function of indoor units is adding to price of system but it is possible to have same level of control as with VRF systems.
I don't know how well is your area developed regarding technicians skills, but what is the point to have high efficient and high-tech system which need high skills and good logistic when that are not locally available. It cannot perform at its high level without that.
Maybe I am wrong in my perception of your surrounding, but that is what i think in general about use of high tech equipment.
Would you drive your Ferrari thru desert? I suppose only if it is off-road version.Last edited by nike123; 28-09-2009 at 12:44 PM.
28-09-2009, 02:44 PM #5
28-09-2009, 03:43 PM #6
Just use normal inverter splits.(or fixed speed if you have power problems)
Use the indoor unit which suits your requirement
Using a chiller or VRV means all your eggs are in one basket. Don't risk that. If you lose one split you can still use all the others so just move to cooler room till it's fixed. This is important in a hot country
Cheaper cost to buy, install and maintain too remember
Mitsubishi, Daikin Toshiba or anyother Japanese manufacturer who has a network in the country/region
Don't try to be too cleaver -this is not a rocket ship you are making
We are free to install next week no problem
28-09-2009, 12:36 PM #7
Excuse my stupid questions, as I said earlier I am with zero experience at the AC field.
1- I guess that there shouldn't be any problem about the technical support..
2- My concern is to have the cooling system concealed at my house public areas.
3- Power saving is a must.
4- Controlling the cooling system of each room is also required. I am looking for a system where the power consumption is relative to the number of operative rooms; so if the AC is operative in one room only, the consumption is definitely much less than if the AC is operative in the whole house.
28-09-2009, 01:11 PM #8
- Join Date
- Sep 2007
- Location
- Split Croatia
- Age
- 57
- Posts
- 6,151
- Blog Entries
- 6
- Rep Power
- 36
That is not my general impression, and I do some technical support for both VRF (Fujitsu, Mitsubishi) and chiller (various) systems. I would say that, mainly, VRF systems suffer more because of required higher level of technician knowledge and less tolerance (or even zero tolerance) for not OEM parts. Not to speak about unability to combine units of two manufacturers or even different generations of same manufacturer. Also chiller installations lasts at least 30 years and they don't care what manufacturer unit is connected to them.
Contrary, VRF system life expectancy is about 15 years and then they, generally, need complete system (together with installations) replacement.
Use of 3-way valves, electronically regulated circulation pump/pumps, zones and multistage chillers or chillers with inverter compressors is a solution to lower price of production of cooling energy that your house need.
Al above said is my personal belief from my experience as 15 years foreman/service chief in HVAC and Refrigeration equipment instalation and maintenance company.Last edited by nike123; 28-09-2009 at 01:33 PM.
28-09-2009, 03:52 PM #9
28-09-2009, 05:21 PM #10
- Join Date
- Sep 2007
- Location
- Split Croatia
- Age
- 57
- Posts
- 6,151
- Blog Entries
- 6
- Rep Power
- 36
No, I install it here on regular basis heating/cooling with added benefit of free hot water in cooling season.
In any case, do you recommend any other technology than the (complicated) VRF and the Chiller system?
28-09-2009, 05:37 PM #11
I am obviously going for a multiple "single split units" where some are going to be ducted (concealed) and some are wall mounted.
The only remaining unclear issue is: "Inverter Split Units" VS "Fixed Speed Split Units".
The country where this system is going to be installed has power problems. Can someone please comment on the power issue and the Inverter Split units? is it not as rugged as the fixed speed system?
28-09-2009, 11:11 PM #12
Maybe your climate is good for evaporative water chiller unit?
Newbie looking for advice on fuel cooling
By madmac in forum New to REReplies: 27Last Post: 27-11-2010, 01:22 PM -
House heat pump use in Croatia
By David Hu in forum Heat PumpsReplies: 1Last Post: 03-07-2009, 08:06 AM -
Questions about NH3 from a wantabe newbie
By Minuteman in forum NH3Replies: 6Last Post: 10-04-2007, 12:46 PM -
Advice for newbie - please be kind..!
By electricstuff in forum Air ConditioningReplies: 11Last Post: 04-10-2004, 06:52 PM
