Results 1 to 2 of 2
    milar's Avatar
    milar Guest
    Carrier 23xl/turbocor retrofit
    I am about to start a retrofit of a 23xl with 2-120ton turbocors. This will be a r-22 conversion to 134a. My question is, is there a problem with leaving the float in as a metering device instead of introducing a exv. After looking over manufactures specs I cannot determine the issue with usinig the high side float regaurdless of the refrigerant it is 134a or 22. If there are any other tips they would be apprieciated. Thanks
    Aug 2009
    New Zealand
    2,554
    26
    Re: Carrier 23xl/turbocor retrofit
    You will have a different pressure differential across the float port (orifice) you need to check that you will achieve the correct flow of the new refrigerant at design pressure, your float manufacture should be able to give you this
  1. Replies: 12
    Last Post: 27-03-2011, 04:12 AM
  2. Carrier Chillers
    By Ed Burris in forum Technical Discussions
    Last Post: 27-03-2010, 02:00 AM
  3. Geoff in NY ~ Carrier Parts
    By Futsal1st in forum Trouble Shooting
    Last Post: 30-12-2009, 04:07 AM
  4. Help identifying carrier HiWall dom. split
    By paul_h in forum Air Conditioning
    Last Post: 12-12-2008, 09:12 AM
  5. Carrier Pro Dialog Plus help
    By borodave1973 in forum Air Conditioning
    Last Post: 11-11-2007, 06:47 PM
