Results 1 to 8 of 8
Thread: Belt Tensioner?
27-09-2009, 02:09 PM #1
Belt Tensioner?
Whats the best Belt Tensioner to buy? and where can i buy it ? im from the uk need a good one
27-09-2009, 04:50 PM #2
Re: Belt Tensioner?
Robinair is making very good belt tension gauges
27-09-2009, 08:47 PM #3
Re: Belt Tensioner?
Were can i buy one? cheers
27-09-2009, 09:19 PM #4
Re: Belt Tensioner?
Have you tried Fenners/wyco/eriks?
Marc
27-09-2009, 11:05 PM #5
Re: Belt Tensioner?
Slightly of subject but I have found, that that a simple twisting of the belt to maximum of 90 degrees, gives the correct tension on "V" belts, it seems to work on all sizes. I am not saying do not measure with the correct tools, but if nothing else should give you a very good starting point
28-09-2009, 06:34 AM #6
Re: Belt Tensioner?
For belt tension gauges, you can find instruments ranging from under a hundred bucks to close to a grand $ - check the GATES Krikit to the Leitenberger ( for Porsche !)- do a Google search of famous belt brands Gates, Optibelt, Bando, Mitsuboshi etc. They all have technical and applications info.
Nothing wrong with old rule of thumb either - " 1/2 in deflection at the longest span" for A or B section belts.
Polyvees are slightly different situation.
For actual automotive/ insustrial mechanical belt tensioner assemblies and applications, check out ROSTA from Switzerland.
regards
T-PRemember what Augustus once said:
"festina lente" - make haste, slowly!
28-09-2009, 07:30 PM #7
Re: Belt Tensioner?
Any one got a website where i can actually buy one? that sends to the UK?
28-09-2009, 11:04 PM #8
Re: Belt Tensioner?
as marc said speak to your local eriks
http://www.eriks.co.uk/branchfinder/
they got me one in a few days and didnt cost the earthPaul
"KEEP IT COOL"
Belt driven marine Reefer compressors
By THERMALBLAST in forum FundamentalsReplies: 3Last Post: 07-09-2009, 04:25 AM -
Belt tightening tool
By marc5180 in forum Tools and CalculatorsReplies: 13Last Post: 02-09-2008, 09:27 PM -
MD-II Max Belt diagram
By lherring81 in forum TransportReplies: 6Last Post: 27-08-2008, 01:16 AM -
SL200e belt slip/chucking belts
By gravy258 in forum TransportReplies: 6Last Post: 26-04-2008, 04:07 AM -
Thumb rule for belt driven compressor - Power loss
By smpsmp45 in forum NH3Replies: 4Last Post: 27-09-2007, 09:26 AM
