Thread: Belt Tensioner?
    Aug 2009
    Dartford
    88
    Belt Tensioner?
    Whats the best Belt Tensioner to buy? and where can i buy it ? im from the uk need a good one
    Aug 2009
    Turhona.libya
    79
    Re: Belt Tensioner?
    Robinair is making very good belt tension gauges
    Aug 2009
    Dartford
    88
    Re: Belt Tensioner?
    Were can i buy one? cheers
    Mar 2006
    Lancashire
    1,859
    28
    Re: Belt Tensioner?
    Have you tried Fenners/wyco/eriks?
    Marc
    Aug 2009
    New Zealand
    2,554
    Re: Belt Tensioner?
    Slightly of subject but I have found, that that a simple twisting of the belt to maximum of 90 degrees, gives the correct tension on "V" belts, it seems to work on all sizes. I am not saying do not measure with the correct tools, but if nothing else should give you a very good starting point
    Feb 2005
    Hong Kong
    190
    Re: Belt Tensioner?
    For belt tension gauges, you can find instruments ranging from under a hundred bucks to close to a grand $ - check the GATES Krikit to the Leitenberger ( for Porsche !)- do a Google search of famous belt brands Gates, Optibelt, Bando, Mitsuboshi etc. They all have technical and applications info.
    Nothing wrong with old rule of thumb either - " 1/2 in deflection at the longest span" for A or B section belts.
    Polyvees are slightly different situation.
    For actual automotive/ insustrial mechanical belt tensioner assemblies and applications, check out ROSTA from Switzerland.
    regards
    T-P
    Remember what Augustus once said:
    "festina lente" - make haste, slowly!
    Aug 2009
    Dartford
    88
    Re: Belt Tensioner?
    Any one got a website where i can actually buy one? that sends to the UK?
    Apr 2006
    stafford
    42
    974
    Re: Belt Tensioner?
    as marc said speak to your local eriks
    http://www.eriks.co.uk/branchfinder/
    they got me one in a few days and didnt cost the earth
    Paul
    "KEEP IT COOL"
  1. Belt driven marine Reefer compressors
    By THERMALBLAST in forum Fundamentals
    Last Post: 07-09-2009, 04:25 AM
  2. Belt tightening tool
    By marc5180 in forum Tools and Calculators
    Last Post: 02-09-2008, 09:27 PM
  3. MD-II Max Belt diagram
    By lherring81 in forum Transport
    Last Post: 27-08-2008, 01:16 AM
  4. SL200e belt slip/chucking belts
    By gravy258 in forum Transport
    Last Post: 26-04-2008, 04:07 AM
  5. Replies: 4
    Last Post: 27-09-2007, 09:26 AM
