23-09-2009, 02:31 PM #1
Grasso sh e-1 screw compressor manual
Hi Guys,
I wonder if someone of you have the Grasso Screw compressor E-1 manual, or tell me where I can get it.
Thanks in advance.
Sandro
08-11-2010, 03:48 PM #2
Re: Grasso sh e-1 screw compressor manual
If you get it. Pls share me
Thank Sir
08-11-2010, 05:23 PM #3
16-11-2010, 07:50 PM #4
Sandro, check your Email
17-11-2010, 09:30 AM #5
Thanks a lot cricri. I will share it with AVICO and with the other guys of the REF. Hope you don't mind.
Guys this manual is excellent. You can thanks a lot to cricri.
From my dropbox.
http://dl.dropbox.com/u/9777572/grasso%20small-CDE.pdfTo make progress is never good enough, I want to do better and better and better
Grasso Single Screw Compressor
By Sturt in forum History of RefrigerationReplies: 7Last Post: 24-02-2010, 09:09 AM -
Slide valve wear on Grasso screw after just 54000 Hrs
By Lodiev in forum Technical SpeculationsReplies: 11Last Post: 14-09-2009, 01:21 PM -
Compressors - screw or reciprocating?
By Josip in forum Industrial CompressorsReplies: 18Last Post: 27-01-2009, 10:36 PM -
Grasso SP2 two-stage ammonia screw compressor package.
By Jacek in forum NH3Replies: 2Last Post: 25-01-2009, 12:17 PM -
Grasso screw comp unit acad drawings
By Josip in forum Industrial CompressorsReplies: 2Last Post: 07-09-2008, 07:19 PM
