    Dec 2008
    Portugal
    48
    1,020
    Grasso sh e-1 screw compressor manual
    Hi Guys,
    I wonder if someone of you have the Grasso Screw compressor E-1 manual, or tell me where I can get it.
    Thanks in advance.
    Sandro
    avico's Avatar
    avico Guest
    Re: Grasso sh e-1 screw compressor manual
    If you get it. Pls share me
    Thank Sir
    Dec 2008
    Portugal
    48
    1,020
    Quote Originally Posted by avico View Post
    Thank Sir
    I couldn't get it
    Nov 2009
    france
    64
    225
    Sandro, check your Email
    Dec 2008
    Portugal
    48
    1,020
    Thanks a lot cricri. I will share it with AVICO and with the other guys of the REF. Hope you don't mind.
    Guys this manual is excellent. You can thanks a lot to cricri.
    From my dropbox.
    http://dl.dropbox.com/u/9777572/grasso%20small-CDE.pdf
  1. Grasso Single Screw Compressor
    By Sturt in forum History of Refrigeration
    Last Post: 24-02-2010, 09:09 AM
  2. Slide valve wear on Grasso screw after just 54000 Hrs
    By Lodiev in forum Technical Speculations
    Last Post: 14-09-2009, 01:21 PM
  3. Compressors - screw or reciprocating?
    By Josip in forum Industrial Compressors
    Last Post: 27-01-2009, 10:36 PM
  4. Replies: 2
    Last Post: 25-01-2009, 12:17 PM
  5. Grasso screw comp unit acad drawings
    Last Post: 07-09-2008, 07:19 PM
