Thread: Defrost scheme
22-09-2009, 04:34 PM #1
Defrost scheme
Can anybody tell me what is the best method (least cost and most reliable!!) to defrost a water-to-air source heat pump? Thae heat pump is packaged and not split.
I know of one way to use a reversing valve; heat the frosted air coil (make it condenser) and then switch back to heating mode once the ice is melted.
Is there any other way (not electrical defrost) ?
22-09-2009, 11:27 PM #2
Re: Defrost scheme
Err, no; not simpler.
23-09-2009, 10:02 AM #3
Re: Defrost scheme
Hot gas defrost, inject hot vapour after expansion device,
23-09-2009, 10:06 AM #4
- Join Date
- Sep 2007
- Location
- Split Croatia
- Age
- 57
- Posts
- 6,151
- Blog Entries
- 6
- Rep Power
- 36
Re: Defrost scheme
Is that heat pump also used for cooling?
Toshiba RAV SM/SP1400 defrost problem
By SteinarN in forum Heat PumpsReplies: 11Last Post: 20-02-2008, 04:25 PM -
No Power for Defrost Timer Motor
By kln in forum DomesticReplies: 6Last Post: 21-01-2008, 08:22 AM -
TK basic micro-p features and functions
By REEFER-TEK in forum TransportReplies: 0Last Post: 05-12-2007, 06:25 PM -
Hot gas defrost vs Electric defrost
By herdian in forum IndustrialReplies: 19Last Post: 13-08-2007, 11:25 PM
