    dyzzypyxxy's Avatar
    dyzzypyxxy Guest
    Error code C6 on LG Mini Split
    We installed an LG Mini Split in May, and it has run great until last night. When I turned it on it ran for about 3 minutes then quietly shut off, and displayed C6 on the blue display on the wall unit. The remote would not shut it off or have any effect. We flicked the breaker, which seemed to re-set it, then it just did the same thing. Anybody have an idea what the C6 error code means?
    Split Croatia
    6,151
    Re: Error code C6 on LG Mini Split
    Inverter compressor run current high.
    Call installer/dealer, it should be covered with warranty.
  1. Mini split load method
    By Acrisoft in forum Air Conditioning
    Last Post: 18-12-2010, 02:33 PM
  2. Mini split system heating, but not cooling well.
    By tirider in forum Heat Pumps
    Last Post: 06-11-2009, 09:17 PM
  3. Need help trouble shooting mini split ac error code "e4"
    By grindrx in forum Air Conditioning
    Last Post: 23-07-2009, 08:57 PM
  4. Prime mini split
    By efrain in forum Air Conditioning
    Last Post: 09-06-2009, 04:15 AM
  5. Klimaire mini split installation
    By JohnK in forum Air Conditioning
    Last Post: 19-05-2009, 07:51 PM
