Thread: dye
18-09-2009, 11:20 AM #1
- Join Date
- Sep 2009
- Location
- Iran
- Age
- 66
- Posts
- 672
- Blog Entries
- 1
- Rep Power
- 19
dye
What is dye and What is purpose of using dye in system?
18-09-2009, 12:20 PM #2
Re: dye
Used for finding leaks on system. Not my favourite but some people use it.
It mixes with the oil and goes around the system.
If refrigerant leak out the dye leaves a stain, which you normally need a UV light and glasses to see.Tony
18-09-2009, 04:14 PM #3
Re: dye
not my favourite either, but it is useful on some systems with long pipe runs etc, annual checks can be speeded up,although totally useless in good light levels, ie outside!! i've been let down badly enough by ropey electronic detectors to keep it as an option
