17-09-2009, 05:53 AM #1
Maximum water ppm levels for refrigerants
Hi, a green newbie requiring assistance,
We are responsible for piston compressors and high speed vane type compressors on the gas recovery refrigeration on a gas to plastic plant.
Question is;
" what is the 'allowable' water level in ppms the mineral oil lubricant in use?"
Our test results came back as 469 ppm and we resampled a day later and the water was 68 ppm, sampling proceddure and condition exactely the same.
The concern is water was not detected in previous analysis causing other questions of
"Can the system conceal water and release it later?"
"Is there any chemical reaction in the system that could create water?"
Thanks in advance for any assitance you can give
Rob S
17-09-2009, 06:31 AM #2
Re: Maximum water ppm levels for refrigerants
What refrigerant, what oil, have you had service problems between testing (has the system been opened)
17-09-2009, 07:32 AM #3
Hi MF
Thanks for the reply
I'm talking with them tommorrow and will get the info,
Thanks and regards
Rob S
(Me Wairarapa Boy, what area are you guys from)
17-09-2009, 08:20 AM #4
Rangiora (chch)
17-09-2009, 10:20 AM #5
Oil added to system , is it sealed or open to atmosphere where it could absorb moisture or water .
Maybe you could sample it for a base .
Also does system run in a vacuum as I'm assuming its on ammonia ?
How old is system and is the water effecting anything that you know of ?
22-09-2009, 12:41 AM #6
Hi Thanks for the asstance
The Carrier chillers operate on Hydrofluorocarbon (HFC) R 134a
Each chiller has a nominal charge of approximately 748 Kg per chiller.
OIL MANUFACTURER: CASTROL
OIL TYPE: ICEMATIC SW
We are wishing to know the maxppm water for stability and also Max TAN before servicing
Thanks in advance for the assitance
regards
Rob S
Fact or Fiction
By david.findlay in forum FundamentalsReplies: 40Last Post: 09-03-2009, 06:19 PM -
pure water from air
By Lc_shi in forum New TechnologiesReplies: 32Last Post: 26-02-2009, 12:25 PM -
Modifying aricond. for heating, cooling and hot water
By kimusabi in forum Technical DiscussionsReplies: 3Last Post: 10-10-2008, 07:28 AM -
open cycle R718 A/C that also provides high purity water?
By star882 in forum Technical SpeculationsReplies: 7Last Post: 27-07-2006, 04:18 AM -
Building a wine cabinet
By Rory in forum Technical DiscussionsReplies: 38Last Post: 13-07-2004, 08:28 PM
