Results 1 to 8 of 8
16-09-2009, 04:40 PM #1
What an idea to drain the oil from hermatic compressor .
When it comes to drain the oil from hermatic compressor i noticed that many suggested drilling a hole in the bottom of the compressor's crankcase. I wonder how this silly idea will work .i would advice those who wanted to drain the oil or replace it not to follow this silly ideas. replacing or draining the oil should be made in a save manner to the technicin, equipment,and to the environment.
16-09-2009, 05:28 PM #2
- Join Date
- Sep 2007
- Location
- Split Croatia
- Age
- 57
- Posts
- 6,151
- Blog Entries
- 6
- Rep Power
- 36
Re: What an idea to drain the oil from hermatic compressor .
Then show us how.
Don't forget, word is about hermetic rotary compressor with suction accumulator attached.
17-09-2009, 06:30 AM #3
simple.send it off to be remanufactured.lol
17-09-2009, 07:43 AM #4
I think that people were referring to draining the oil prior to disposing of the compressor !
CheersTutto il Mondo e un Paese
17-09-2009, 01:08 PM #5
el padre i agree 1000% still lol
27-02-2010, 04:57 PM #6
you can simply turn it over so the oil will drain frm the suction pipe!
27-02-2010, 11:35 PM #7
03-03-2010, 11:16 AM #8
make an entrance on the suction side by way of a "T" welded in between. make the suction pipe side ways en weld a valve on the other end. make it so that it is possible to enter the pipe whit a small tube connected to a manual oil pump.
works fine for me.
Ice
Suction gas <-> liquid line heat exchange and performance gains
By DaBit in forum Technical SpeculationsReplies: 30Last Post: 18-05-2010, 01:52 PM -
Help needed to find a replacement compressor
By 540itouring in forum DomesticReplies: 19Last Post: 17-04-2010, 02:06 PM -
replacing R12 comp with POE compressor
By Richvacr in forum CommercialReplies: 5Last Post: 02-05-2009, 07:04 AM -
screw compressor
By vinod in forum Trouble ShootingReplies: 9Last Post: 17-12-2005, 01:46 AM -
Starting a compressor, and receiver questions.
By DaBit in forum Technical SpeculationsReplies: 9Last Post: 24-08-2002, 12:37 PM
