Results 1 to 2 of 2
Thread: Aux fan for tropical fridge
12-09-2009, 08:33 PM #1
Hey all
I'm thinking about adding an aux cooling fan to help move more air across the compressor and out the front of a GE profile side by side fridge.
It cools sufficiently, but the floor under the fridge gets pretty hot and i imagine some of the compressor heat end up warming the fridge itself.
My idea is to add a 30CFM (approx) 120mm 'case fan' to the back of the fridge, aimed at the compressor.
the added air movement should help evacuate heat from the condensor (a little) as well.
Is this a waste of time? Might it increase the efficiency of the fridge? The fan is cheap at about $15, so it it saves me 5% on power to run the fridge, it'll pay for itself in under a year (and might help the components of the fridge last longer)
Thoughts?
incidentally: I plan to run the fan from a +12v lead that appears to be intended for a "CC fan- Optional" on the wiring diagram
13-09-2009, 09:57 AM #2
Re: Aux fan for tropical fridge
Yep, go for it.
The more added cooling for the compressor an/or the condenser the better.
and go get a cuppa
Hotpoint Mistral Plus - Fridge Freezer
By cozzie121 in forum DomesticReplies: 9Last Post: 19-09-2010, 08:45 AM -
Indesit FROST FREE Fridge Freezer - fridge not cold
By pauby in forum DomesticReplies: 26Last Post: 09-03-2009, 11:04 AM -
John Lewis, fridge warm but freeze ok
By netingit in forum DomesticReplies: 4Last Post: 21-08-2008, 01:23 AM -
help- my bar fridge is wacko?!
By ben in forum Trouble ShootingReplies: 3Last Post: 25-01-2002, 12:06 AM -
is my fridge working properly?
By vincec in forum Trouble ShootingReplies: 1Last Post: 15-01-2002, 09:55 PM
