Thread: thermic signal switch
17-09-2009, 05:42 PM #1
Some guidance for a layman please..
My girlfriends freezer defrosted itself yesterday for no apparent reason.
I just took a look at the back and there is a little tiny box on a wire that looks like it should be attached to the radiator. but was just hanging there. it clips nicely back on to the pipe but couldnt see exactly where it was.Is it vital where its clipped?
Could this be the cause? There is a wiring diagram on the back that mentions thermic signal switch and im guessing this is what it is and the reason the freezer wouldnt freeze up?
Even with the switch replaced it doesnt cool down so seems like maybe this has caused more problems and ill have to get someone in
Its a new world nw801fz built in freezer.
cheers
andy
19-09-2009, 09:19 PM #2
Re: thermic signal switch
Will be the sensor,should be clipped or fastened onto evaporator plate.
If it's not freezing at all and the compresoor is running then you have a system fault,perhaps leak.
If the compressor isn't running you will have a control or compressor problem.
flow switch connection
By afeef in forum The Trail of TearsReplies: 18Last Post: 23-12-2009, 06:55 PM -
Low Pressure Cut-off switch on Liquid line
By Vishnukurup in forum Air ConditioningReplies: 14Last Post: 03-12-2008, 09:34 AM -
Hermetic analyzer " ANNIE" how do they work
By kengineering in forum Tools and CalculatorsReplies: 11Last Post: 02-03-2008, 06:10 PM -
RCV and HIGH PRESSURE SWITCH
By abbasi in forum FundamentalsReplies: 3Last Post: 22-03-2006, 08:51 AM -
shower switch fault !
By Krups in forum ElectricalReplies: 10Last Post: 19-10-2005, 09:10 PM
