Thread: Efficient Tri-Generation Systems
11-09-2009, 07:38 PM #1
Best Wishes from Germany!
Double-effect/single-effect absorption chillers allow for a direct utilization of hot flue gases in
parallel to the conventional coupling to the hot water loop of co-generation systems. These innovative
tri-generation systems exhibit a 30% increase in COP and chilling capacity in comparison
to standard systems comprising single-effect chillers only. Two pilot plants are being
erected and analyzed with special regard to an innovative coupling scheme. For compact systems,
a flue gas driven regenerator is designed and tested for utilization in the upper stage of
the two-stage chiller.
German text, but u can als see a P&ID of the plant.
www zae-bayern.de/files/eff_kwkk.pdf
with kind regards,
Kevin
07-03-2010, 09:52 PM #2
07-03-2010, 11:16 PM #3
Re: Efficient Tri-Generation Systems
Jacek,
Try the corrected link...
http://www.zae-bayern.de/files/eff_kwkk.pdfBrian - Newton Abbot, Devon, UK
Vrv
By tgoonter in forum Air ConditioningReplies: 4Last Post: 11-01-2011, 06:25 AM -
Sensible Heat Factor / capacity of Inverter split Systems at part load?
By Greengrocer in forum Technical SpeculationsReplies: 31Last Post: 09-02-2009, 04:57 PM -
Super efficient, low carbon footprint, etc etc - ideas?
By Makeit go Right in forum Air ConditioningReplies: 8Last Post: 05-12-2007, 05:56 PM -
Co2 Systems in Supermarkets
By 750 Valve in forum Supermarket RefrigerationReplies: 22Last Post: 19-10-2007, 08:51 AM
