Results 1 to 8 of 8
    Jul 2002
    Derby
    74
    22
    What is a High suction pressure ?
    hi all
    was just wonderihat exactly is a High suction pressure , people talk about suction pressure being too high,
    But what exactly is too high ?
    A high heat load / Temperature will give a high suction pressure , but when is it too high ? if the compressor isnt pumping to capacity wouldnt the Suction pressure rise , but how do you define this ?
    Split Croatia
    57
    6,151
    36
    Re: What is a High suction pressure ?
    Quote Originally Posted by kfjoe View Post
    hi all
    High suction pressure is when suction pressure is converted to saturation temperature and if that temperature is higher than result of this equation.
    SST= evaporator entering air temperature - evaporator TD
    SST=suction saturation temperature
    TD=evaporator designed Temperature Diference
    http://www.refrigeration-engineer.co...75&postcount=5
    Aug 2009
    New Zealand
    2,554
    26
    hi all
    I think you have the right understanding!
    So I think you asking about the practical side.
    You are asking 2 questions,
    1; The compressor is working correctly?
    Suction pressure is to high, if it is higher that the manufactures working enverlope (specs)
    Most of the time you will not have this with you, so practically, it is to high if the moter current is equal to that of the name plate, or if the discharge pressure is too high (similar result increased moter current) This why you install CPR say for instance on a large freezer.
    2; The compressor in not working correctly?
    No finite number, First thing to look for is high suction and low discharge pressures, this can give an indication that the comp may be faulty (but is not the only fault that can give this set of readings)
    Aug 2009
    New Zealand
    2,554
    26
    In service you should always use your 4 best tools first,
    Brains, Eyes, Ears, and fingers
    Oct 2003
    5,630
    34
    Hey Mad Fridgie, that's really a good one to remember.
    Aug 2009
    New Zealand
    2,554
    26
    Hi Peter_1, I wish somebody had given this advice to me early on in my trade, It would of saved a bit of wear and tear on the old knees and back
    Feb 2008
    Las Vegas, NV
    67
    330
    Here's a link to some quick references for troubleshooting systems. Check out the "High Suction Presure" section.
    http://www.hvacrinfo.com/system_trouble.htm
    Thousands of HVACR manufacturers links! Visit: www.hvacrinfo.com
    Blythe Warland's Avatar
    Blythe Warland Guest
    A high suction pressure would be dependant on the expected pressure / temperature of the evaporator.
    If the pressure / temp is higher than designed then it would be a high suction pressure. Just remember that for a freezer, cool room or a/c these pressure / temps all differ, then you have the different refrigerants as well
    Blythe
  1. need help! compressor kicking out on high pressure
    By SloFuse in forum Trouble Shooting
    Last Post: 19-08-2009, 04:46 PM
  2. Pressure drop through the suction line accumulator?
    By frank721 in forum Technical Discussions
    Last Post: 14-07-2009, 06:06 AM
  3. High Suction Temps
    By freezerman11 in forum Trouble Shooting
    Last Post: 30-06-2009, 08:11 PM
  4. Benji
