    Apr 2009
    perth, scotland
    48
    10
    manufacturing a small test rig
    Hi all, I am hoping to make a small system in my shed for practicing, setting, learning about SH and SC etc etc. I have been working with refrigeration for around 7 years now but until a short time ago it was only a very small part of my job and did not make much of an attempt to understand it. I now have a job as e ref/air con engineer and want to learn more than just the very basics. I have all the kit required and know how to use it safely. I basically want to be able to play about with different charges, TXV/orrifice so I can actually see what is happening in the system and where. Now that things have calmed down after that hot spell of weather I have time to start teaching myself more. What would be a good start as far as sizes of compressor, evap and condens coild etc (single phase only)
    thanks in advance
    daz
    Aug 2009
    New Zealand
    2,554
    Re: manufacturing a small test rig
    I have found when training others in the basics, it is some times easier to use water to water systems (evap and cond) these can be manually controlled to give a range constants.
    I would choose a semi-hemitic comp (air/water cooled motor) suction pipe direct in the head. Brazed plate heat exchangers, reciever and good size accumulator. Add a bit glycol to your cooling side if you want to try lower temps. (you do not want feeze the evap)
  1. Leak Testing?
    By Thana in forum Trouble Shooting
    Last Post: 31-08-2010, 02:57 PM
  2. Daikin VRV II Test Mode Failure
    By KISS KISS BANG in forum Air Conditioning
    Last Post: 30-05-2010, 08:54 PM
  3. Test
    By bigblock468 in forum New to RE
    Last Post: 04-06-2008, 11:16 PM
  4. crazy 3rd-world idea: aircon from small fridge
    By lsemprini in forum Fundamentals
    Last Post: 29-05-2008, 01:10 AM
  5. Small Chillers
    By Sledge in forum Commercial
    Last Post: 08-05-2007, 05:41 AM
