    Nov 2008
    Ireland
    FOSTER Gastronom-90 GH1350T Specs?
    Hello,
    An unusual one, this - one of my customers has a 21 year old Foster cabinet, it is adapted for hanging game (he is an avid shooting enthusiast). He salvaged it from a factory that was closing, but it has just packed in now. Compressor fine, but definitely no gas, just a hint of cooling where the capillary is soldered to the evaporator. Model number is GH 1350T, it uses R12 and the compressor is a Tecumseh CAJ4461A. Have seen some stuff on the forum re. Foster cabinets and concur with the crappy quality of the copper plumbing - it is quite discoloured & corroded, both inside & out and the evap. coil does not look great either. Cabinet has two doors, it is approx 55" wide, 24" deep & 60" high. Evaporator is fitted into an internal plenum chamber which has a circulation fan and is approx 4" x 4" x 12" in size. Very basic system, just a capillary and a Ranco stat with its bulb mounted on the evap. coil, no expansion valves or fancy electronics. A small bulb, approx 1" x 5" is mounted on the suction line from the evaporator - this seems to perform the task of a rudimentary receiver. Trouble is, there is no data, the label is long worn off re. refrigerant quantity etc. Also, the compressor is only rated for R12. Any suggestions re. drop in replacements and replacement evap coil? - or would someone have any specs on this model? The owner is anxious to keep the cabinet as it was expensive to have the racking wtc modified for hanging the game, the cabinet itself is in very good condition. Many thanks
    Jul 2008
    London
    849
    11
    Re: FOSTER Gastronom-90 GH1350T Specs?
    Take the comp details and ask your local wholesaler or try SRW and they will quote you something. Beehive coils used to make Foster coils so you might try them too
    ireland
    47
    1,279
    33
    go to http://www.foster-spares.com/ and search for an equivelent, parts are priced and easier to deal with than Cross's.
    al
    Nov 2008
    Ireland
    Thanks, will try them, just got the comp data from some obscure Russian website but it's in english...
  1. carrier phoenix advantage specs
    By west texas in forum Transport
    Last Post: 26-06-2009, 06:12 PM
  2. Blind Cold room specs help
    By frostedflake in forum Trouble Shooting
    Last Post: 13-03-2009, 02:49 AM
  3. Foster walk in freezer
    By ActiveEngineer in forum Trouble Shooting
    Last Post: 24-02-2009, 12:53 AM
  4. Foster query
    By eam1956 in forum Commercial
    Last Post: 23-01-2006, 10:37 PM
