    Dec 2004
    U.K
    55
    518
    21
    Scandinova L7-111w thermostat change?
    Hi guys,
    Have a mate who lives some distance away from me with a Scandinova L7-111W. He says the light comes on but nothing happens so I am guessing the thermostat is U/S.
    I am not local to him so can't have a look so can anyone tell me how he can strip the unit to access the t/stat?
    cheers,
    djbe.
    Sep 2008
    Letsby Avenue
    359
    Re: Scandinova L7-111w thermostat change?
    Is it a fridge or fridge freeezer,and hs it electronic controls ?
    BG
    Dec 2004
    U.K
    55
    518
    21
    Hi BG,
    It's a fridge, standard dial thermostat (the type you use a coin to turn).
    Cheers,
    djbe.
    Sep 2008
    Letsby Avenue
    359
    presuming there is no internal fan!
    The thermostat phial is usually fastened to the evaporator by 2 screws low down on the plate which will either unclip or has retaining screws the evaporator will pull slightly forward, a danfoss no 3 would be OK,the condenser at the rear may have to be released to allow entry of phial into rear of cabinet.
    It's likely the body fits in the top facia, then feed the phial down the back and into cabinet.
    Dec 2004
    U.K
    55
    518
    21
    Thanks for the info.
    regards,
    djbe.
  1. Basics or is it?
    By Fett in forum Fundamentals
    Last Post: 10-09-2009, 01:45 AM
  2. Whirlpool Fridge Thermostat
    By HVACRSA in forum Domestic
    Last Post: 19-08-2009, 08:10 PM
  3. VRV & Thermostat
    By hahung in forum Technical Discussions
    Last Post: 08-01-2009, 08:59 AM
  4. defrost thermostat closed failure
    By rkmoorthy in forum Trouble Shooting
    Last Post: 02-03-2008, 10:55 PM
  5. Change BRC1D528 for X10 Thermostat
    By creible in forum Air Conditioning
    Last Post: 07-01-2008, 09:35 PM
