Thread: Eutectic plates
    Nookymonsta's Avatar
    Nookymonsta Guest
    Eutectic plates
    Hi guys, first up let me say I know very little about refrigeration apart from the principles of it
    I'm trying to build my own Eutectic plates for a fridge/freezer which has to deal with very high ambient temps (up to 50c)
    I've sorted the compressor side (Going to run a Danfoss BD 80F)
    My main concern is that I will be in remote locations for extended periods of time so energy efficiency is critical
    I've nutted out the construction of the actual plate but my main issue is the solution. I've read another thread on this forum and it seems most of you guys are using Glycol or salt solutions, my issue with those is that they aren't true "Eutectic" solutions and as such don't have as high a thermal capacity and aren't as efficient.
    I've only found two companies in Australia who make such systems and both are hideously expensive and both won't sell their solutions (Or reveal if they are even true Eutectic) solutions
    Here's hoping you guys can help me out or maybe suggest somebody who'll supply it to me
    Jul 2009
    South Africa
    79
    195
    Re: Eutectic plates
    Quote Originally Posted by Nookymonsta View Post
    I might be wrong but think salt solution can be a eutectic if correct in quantities.
    Oct 2003
    5,630
    34
    Re: Eutectic plates
    Why you think a salt solution not eutectic?
    I did the tests long ago with salt, 'the special solutions' from Dupont and glycol.
    Mine lasted longer solid !!
    Now you.
    Nookymonsta Guest
    Re: Eutectic plates
    Classical and temperature-modulated DSC methods used to study aqueous solutions of NaCl in the whole concentration range and the temperature interval of -120°C to 30°C. New interpretation of experimental data based on the state diagram has shown that transitions observed at temperatures below the melting temperature of ice are glass transitions of two amorphous phases in the system—the maximally freeze-concentrated phase (MFCP) and the solution surrounding NaCl crystals. At low temperatures, these solutions pass into the glassy state. Structure of these frozen solutions is inhomogeneous. It includes at least two crystalline phases and two amorphous glasses. This behaviour is characteristic of diluted and semi concentrated solutions. The solutions of composition close to the eutectic one usually freezes directly into glassy solid; during re-heating water crystallises and a liquid phase is separated with a concentration differing from the original concentration of the initial solution.
    Aug 2007
    42
    135
    Re: Eutectic plates
    Any mixture where the mixture freezes lower that either on its own is a eutectic mixture so keep going. My advice is to freeze water as this is the most efficient refrigerant known to man. The efficiency comes from the latent energy required to change the mixture back to a liquid. My advice to you is to buy dry ice. Cheap and efficient to -80'c.
    The Bridge Keeper
    'Answer me these questions three, n'er the other side ye see.'
    What is your name?
    What is your favourite colour?
    What is your suction superheat?
    Oct 2003
    5,630
    34
    Re: Eutectic plates
    A whole mouthful of bla-bla-bla. And now in understandable English please.
    The whole point, does this change anything for your application? This is pure explained on a scientific base. I'm speaking about practical experience of making this plates ourselves since 20 years.
    This is always the case - even when you freeze pure water - unless you should stir continuously while freezing the solution. Are we then speaking of a temperature difference of 0.1K or 10 K and does this matter for a cold storage application?
  1. eutectic plates, calculation, design
    By student in forum Transport
    Last Post: 11-06-2009, 03:57 PM
  2. Eutectic beam/plate.
    By alpha in forum Fundamentals
    Last Post: 21-01-2009, 02:03 PM
  3. Help with eutectic solution please
    By bront in forum Technical Speculations
    Last Post: 06-01-2009, 11:56 PM
  4. Eutectic pads
    By sidhartha in forum Technical Discussions
    Last Post: 04-10-2008, 10:32 AM
  5. Eutectic plates
    By Temprite in forum Commercial
    Last Post: 31-05-2005, 12:13 PM
