Results 1 to 8 of 8
    Apr 2009
    california
    52
    26
    r410a bottle orafice size?
    Has the orifice size been changed in the recent years on disposable bottles. I tried to connect my manifold to the bottle and the hose fits but will not bottom out and leaks at the bottle? Any info would be great.
    11,025
    Re: r410a bottle orafice size?
    Is the hose seal still in good condition?
    Apr 2009
    california
    52
    26
    yes the hose and manifold are in new shape and fit on any other cylinder I am from the maritime industry and we have never used disposable bottles and was wondering if they needed an adapter.
    Jul 2007
    Australia
    1,845
    ARe you using an acme gauge set, or it the cylider fitted with an acme outlet?
    Do you guys over there use 1/4" or 5/16" for R410a?
    1/4" was the standard for all refrigerant bottles, access points and hoses up until R410a for us, R410 is a 5/16" fitting and gauge hose set.
    Apr 2009
    california
    52
    26
    all our 410a equipment is 1/4 in seems to be different standards to maritime verses land stupid.
    Oct 2006
    1,843
    21
    Quote Originally Posted by capthummel View Post
    Does your hose have the insert in to depress the screader valve?
    If it does then that maybe interfering with the fitting if it does not let the hose tighten all the way up.
    Like you said if the hole through the valve is too small it will stop the seal.
    taz.
    Apr 2009
    california
    52
    26
    Quote Originally Posted by taz24 View Post
    taz.
    yes it does I just went out and bought another hose for use on land worked fine.
    Oct 2006
    1,843
    21
    Good to hear you sorted it.
    Cheers taz.
  1. Pipes to large for R410a??
    By Spanglishsparky in forum Technical Speculations
    Last Post: 09-05-2009, 12:57 AM
  2. Fujitsu Window unit Size 9 same size as 6 ?
    By S_Line in forum Air Conditioning
    Last Post: 19-09-2008, 01:05 PM
  3. Pressure Testing for R410a
    By Pooh in forum Tools and Calculators
    Last Post: 13-08-2008, 11:41 PM
  4. R410A captube sizing for 2.5 bar / 35 psi pressure drop
    Last Post: 27-11-2003, 09:05 AM
