Thread: turbomiser?
    Mar 2009
    7
    turbomiser?
    recently come across some statistics about the new turbomiser comepressors. from what it sounds like there are the best think since sliced bread. The noise levels are none existent, 1 unit the same size as a standard lawn mower and it kicks out about 500 kw. has any1 come across these and is there anywhere i can read up on this new technology?
    Jul 2008
    London
    848
    Re: turbomiser?
    Quote Originally Posted by jonjon200 View Post
    Have you used the search...
    Split Croatia
    57
    6,151
    36
    Re: turbomiser?
    You mean Danfoss Turbocor compressor?
    Turbomiser is name of chiller unit which use Turbocor compressor.
    Search this forum with Turbocor key word.
    Nov 2005
    New Zealand
    550
    Re: turbomiser?
    Hi Jon, Look at this
    http://www.turbocor.com/literature/p...turbomiser.pdf
    Norm
    My wife used to say you never listen to a word I say at least I think that what she said
    Jun 2009
    Australia
    34
    5
    Re: turbomiser?
    Alot of the high rise buildings in Sydney are installing these powerpax chillers which incorporate these turbocor compressor. They are a centrifugal type compressor and are oil less. That is they use electromagnetic bearings. They run super quiet. The powerpax chillers which use them that ive worked on draw the same sort of current as a domestic kettle does, real low current draw and the chiller itself can run on loads as low as 1 degree across the vessel
