Thread: Use of schrader valves
30-09-2004, 01:03 PM #1
Is it common practice to use schrader valves under fan cycle switches? For the ease of removal. Systems are less than 20 tons in capacity.
Mark
30-09-2004, 08:12 PM #2
Re: Use of schrader valves
'most' will use a schrader but sadly this isn't always the case
it's that 'is it isn't it?' moment when there is a squirt of liquid...
I have once changed a coupling on a fully charged system (I wrongly assumed it DID have a schreader) got frozen fingies for my efforts but i got them out of trouble..
these days -by law you can only- reclaim/change/recharge and then you can slot that particular make in your memory for next time
cheers
richard
30-09-2004, 08:16 PM #3
So by law are you saying you can't use a schrader?
Mark
30-09-2004, 08:28 PM #4
no but your epa is pretty hot on deliberate refrigerant release and will impose a heavy fine/jail sentence for those caught..
therefore as a 'skilled tech' you could find it quite hard to argue that the release wasn't intentional in front of a judge..
an 'I thought it had one' plea would be deemed ignorance and ignorance is no excuse in the eyes of the law..
be safe and reclaim and you will add time to the job but also add to your credibility as a responsable engineer
cheers
richard
Stainless steel valves
By Tycho in forum NH3Replies: 5Last Post: 05-11-2008, 02:16 PM -
Hinari and how far to open valves
By stryker in forum Air ConditioningReplies: 6Last Post: 14-04-2008, 01:47 AM -
Glycol water valves
By eng_ab in forum IndustrialReplies: 2Last Post: 03-06-2005, 09:15 PM -
setting of hand reg valves
By ecclesk in forum IndustrialReplies: 7Last Post: 21-04-2005, 08:50 PM -
Positon of tx valves
By Les Stuart in forum Trouble ShootingReplies: 5Last Post: 16-11-2003, 04:43 PM
