    Oz Fridgey's Avatar
    Oz Fridgey Guest
    Sabroe Chill PAC reciprocating NH3 inlet valve failure
    I have been working on a Sabroe Chill PAC reciprocating compressor model SMC108L with water cooled condenser. running conditions are - 4 C evaporating / + 40 C condensing. Chilling 12.4% (by weight) ethylene glycol solution from + 2.5 C to - 0.5 C.
    The machine has contant problems with the inlet valve failing. Has anyone else experienced this problem?
    What was the cause and the solution to the problem?
    Oz Fridgey
    Apr 2009
    South Africa
    49
    108
    Re: Sabroe Chill PAC reciprocating NH3 inlet valve failure
    [quote=Oz Fridgey;
    Can u elaborate around the tipe valve?
    3,356
    What do you mean by inlet valve ?
    Suction stop valve
    or cylinder liner suction valve plate .
    What refrigerant and comp speed ?
    What type of evaporator and level control ?
    Jan 2008
    newzealand
    47
    44
    what do you mean by inlet valve? inlet valve plate assembly? failing in which way? is you loading mech. working correctly?
  1. Carrier Transicold Container Problem
    By Shamel in forum Transport
    Last Post: 23-01-2012, 11:23 PM
  2. LEV does not open
    By Yuri B. in forum Air Conditioning
    Last Post: 19-07-2009, 02:37 PM
  3. Valve Reed of Reciprocating Compressors
    By Samarjit Sen in forum Industrial Compressors
    Last Post: 18-03-2008, 02:26 AM
  4. Scotsman commercial H2O inlet valve
    By fullcourt in forum Trouble Shooting
    Last Post: 25-04-2006, 11:41 PM
  5. valve plate failure
    By Andy noblet in forum Trouble Shooting
    Last Post: 04-06-2004, 08:54 PM
