28-08-2009, 04:16 PM #1
Looking for oil equivalent to POE 160
Dear Friend, could someone can suggested me a equivalent oil for R404, the plate spec said POE160,
but I can't find out here (mexico), some stores only have POE 68 or 32, could you use them with out any risk?
Where I can find out oil spec?
Thanks for your comments.
28-08-2009, 04:21 PM #2
- Sep 2007
- Split Croatia
- 57
- 6,175
- 6
- 36
Re: Looking for oil equivalent to POE 160
I think that POE 160 and POE 32 is same viscosity but expresed in diferent units.
Could you give us full oil data: manufacturer, full oil name?
What is compressor full name and model #?
32 cSt (centiStokes) = 150 SUSLast edited by nike123; 28-08-2009 at 04:37 PM.
28-08-2009, 05:58 PM #3
nike123,
the compressor is a danfoss maieurop mtz72hn4a, with oil p.o.e 160 tz, the aplication is in air dryier.
thanks
28-08-2009, 06:20 PM #4
dear friends, i am going out for one day, i will put in touch on Monday,
I appreciate your support
31-08-2009, 06:49 PM #5
I talked to Danfoss about oil for Maneurop compressors and they said that Emkarate RL32H was a equal oil to 160pZ.
/cerwin
31-08-2009, 07:24 PM #6
- Sep 2007
- Split Croatia
- 57
- 6,175
- 6
- 36
Little bit of advice given to me by Danfoss (Maneurop) technical support.
Synthetic (and mineral) oils of different manufacturers have different additives.
It is possible that some of them are incompatible and could react causing compressor/system damage.
I am advised to not mix two oils from different manufacturers.
If Danfoss support has given answer that Emkarate RL32H is same/compatibile oil, than you could try find it.
Or you could contact Danfoss in your area:
México
Danfoss Industries, SA de CV
Carretera Miguel Aleman # 162
66600 Apodaca,
81 Nuevo Leon
GMT: -6
Dial Code: +52
Telephone: 81 1856 5600
Refrigeración y Aire Acondicionado
Tel. 01 800 823 8000
Fax. 81 8156 5624
E-mail: mexico@danfoss.com
01-09-2009, 03:48 PM #7
that "hair dryer" must be heavy with that manurope in,mine just plugs inthe wall socket !
Sourcing a modern equivalent to old USA Copeland compressor
By weeksy in forum Industrial CompressorsReplies: 7Last Post: 15-05-2009, 03:46 PM -
Equivalent Lenght table
By RODRIGO BR in forum Refrigeration BooksReplies: 2Last Post: 23-11-2007, 05:16 PM -
Equivalent length for fittings
By harsen in forum Technical SpeculationsReplies: 12Last Post: 11-04-2007, 05:13 AM
