    Jun 2006
    Mexico
    8
    Looking for oil equivalent to POE 160
    Dear Friend, could someone can suggested me a equivalent oil for R404, the plate spec said POE160,
    but I can't find out here (mexico), some stores only have POE 68 or 32, could you use them with out any risk?
    Where I can find out oil spec?
    Thanks for your comments.
    Split Croatia
    57
    6,151
    36
    Re: Looking for oil equivalent to POE 160
    I think that POE 160 and POE 32 is same viscosity but expresed in diferent units.
    Could you give us full oil data: manufacturer, full oil name?
    What is compressor full name and model #?
    32 cSt (centiStokes) = 150 SUS
    Jun 2006
    Mexico
    8
    nike123,
    the compressor is a danfoss maieurop mtz72hn4a, with oil p.o.e 160 tz, the aplication is in air dryier.
    thanks
    Jun 2006
    Mexico
    8
    Smile Re: Looking for oil equivalent to POE 160
    dear friends, i am going out for one day, i will put in touch on Monday,
    I appreciate your support
    cerwin's Avatar
    cerwin Guest
    I talked to Danfoss about oil for Maneurop compressors and they said that Emkarate RL32H was a equal oil to 160pZ.
    /cerwin
    Split Croatia
    57
    6,151
    36
    Little bit of advice given to me by Danfoss (Maneurop) technical support.
    Synthetic (and mineral) oils of different manufacturers have different additives.
    It is possible that some of them are incompatible and could react causing compressor/system damage.
    I am advised to not mix two oils from different manufacturers.
    If Danfoss support has given answer that Emkarate RL32H is same/compatibile oil, than you could try find it.
    Or you could contact Danfoss in your area:
    México
    Danfoss Industries, SA de CV
    Carretera Miguel Aleman # 162
    66600 Apodaca,
    81 Nuevo Leon
    GMT: -6
    Dial Code: +52
    Telephone: 81 1856 5600
    Refrigeración y Aire Acondicionado
    Tel. 01 800 823 8000
    Fax. 81 8156 5624
    E-mail: mexico@danfoss.com
    Feb 2006
    derbyshire
    610
    that "hair dryer" must be heavy with that manurope in,mine just plugs inthe wall socket !
  1. Sourcing a modern equivalent to old USA Copeland compressor
    By weeksy in forum Industrial Compressors
    Last Post: 15-05-2009, 03:46 PM
  2. Equivalent Lenght table
    By RODRIGO BR in forum Refrigeration Books
    Last Post: 23-11-2007, 04:16 PM
  3. Equivalent length for fittings
    By harsen in forum Technical Speculations
    Last Post: 11-04-2007, 05:13 AM
