    jamiebull1's Avatar
    jamiebull1 Guest
    Cooling load for refrigerated warehouse
    I'm sure this will seem like a very basic question but I'm trying to figure out how much energy it will take to cool a large storage and distribution warehouse.
    There will be 7,500 m2 of freezer warehouse (-18 deg C) and 10,000 m2 of chilled warehouse (1 deg C).
    Is there a benchmark of some sort as in W/m2 or kWh/m2/yr?
    I'm currently working with a figure of 6.86 kW per 1,000 m2 for the freezer warehouse but I can't find anything for estimating the refrigerated warehouse.
    Thanks.
    Blythe Warland's Avatar
    Blythe Warland Guest
    Re: Cooling load for refrigerated warehouse
    you would need a whole lot more information than what you have provided to even give a guesstimate.
    here are some points for you to consider:
    type of insulation
    thickness of insulation
    ambient temperature
    product being stored
    temperature of product entering refrigerated space
    storage
    Pull down, if pull down time required to reach storage temp
    volume of refrigerated space not m2
    hopefully this will help you focus on what you need to determine.
    Blythe
    Nov 2003
    holland europe
    66
    78
    21
    go to a warehouse and ask for the data, and learn learn learn.
    asking here is bit too easy to get your paper.
    computer shooter
    paul deelen
    +31653300739
    xxxxestwwgz's Avatar
    xxxxestwwgz Guest
    New here...Where Should I Start?
    hi i hope i enjoy my stay here pls be nice to me thanks!
    Nov 2010
    Germany
    120
    14
    ~7kW per 1000m2 is 7W per m2. Calculation for the insulation thickness for the floor is 11W/m2...Don't count on that figure please
    Be careful about reading health books. You may die of a misprint.
  1. Cooling Load Calculations
    By hamidpia in forum Tools and Calculators
    Last Post: 05-02-2009, 08:57 PM
  2. Infiltration Cooling Load?
    By Rankin755 in forum Fundamentals
    Last Post: 13-12-2008, 06:26 PM
  3. Heat transfer coefficient - Coolpack
    By Graham in forum Fundamentals
    Last Post: 28-05-2008, 01:08 AM
  4. Compressor loading, cooling, and range of operation.
  5. Cooling Load Calculation
    By jervame_sireh in forum Fundamentals
    Last Post: 21-04-2007, 11:05 PM
