Results 1 to 8 of 8
Thread: scroll compressor
26-08-2009, 03:55 AM #1
scroll compressor
When the compressor starts it some times goes foward then goes backwards. Could the phase moniter change the direction for a few seconds. Anything on scroll would help.
26-08-2009, 06:26 AM #2
Re: scroll compressor
am wondering how you can tell the direction of the compressor is it not sealed
26-08-2009, 09:24 AM #3
- Join Date
- Sep 2007
- Location
- Split Croatia
- Age
- 57
- Posts
- 6,151
- Blog Entries
- 6
- Rep Power
- 36
26-08-2009, 09:40 PM #4
scrolls have a internal non return valve which is a safety because when the compressor stops the discharge pressure does,nt back spin the scrolls ,it only spins back for a second ,until the pressures equilized, which is normal
28-08-2009, 01:33 PM #5
ghaz is spot on ...i know copeland have non return vlvs fitted but not too sure about other brands..
28-08-2009, 01:50 PM #6
- Join Date
- Sep 2007
- Location
- Split Croatia
- Age
- 57
- Posts
- 6,151
- Blog Entries
- 6
- Rep Power
- 36
01-09-2009, 12:02 AM #7
If it is not a millenium compressor, add a 5 minute time delay.
02-09-2009, 04:42 AM #8
hi there a phase monitor is as only a monitor and will not cause a phase change only monitor it and warn u or stop your system when needed
u should go to the copeland site or maneroupe they have a nice "show " and explanation how a scroll works.
http://www.digitalscroll.com/sb300/
enjoy
About Copeland ZB scroll compressor
By ernestlin in forum Technical SpeculationsReplies: 18Last Post: 27-08-2009, 08:39 AM -
Copeland scroll compressor - running capacitor
By desA in forum FundamentalsReplies: 23Last Post: 23-06-2009, 08:05 PM -
Scroll Compressor Seizure
By jwasir in forum Trouble ShootingReplies: 9Last Post: 08-06-2008, 12:52 PM -
Scroll compressor with TXV no Receiver no filter Dryer
By FCS in forum FundamentalsReplies: 7Last Post: 19-06-2007, 10:51 PM -
Scroll Compressor
By dwallan in forum CommercialReplies: 1Last Post: 30-07-2001, 04:18 AM
