    Apr 2001
    Capacitor under sized
    I have a 575 volt single phase condenser fan motor with a 370 volt capacitor.This comes O.E.M. from Carrier.It periodically blows the capacitor,in neighbouring units too...
    Any thoughts?
    Oct 2003
    5,630
    34
    Re: Capacitor under sized
    A capacitor must always be correct sized and even beterr oversized.
    I should contact Carrier for this because this is a warranty case.
    Peter
    Apr 2001
    Its a run capacitor,the motor voltage is 575v.
    I am wondering if the capacitor only sees one leg of the 575 voltage,which would be approxiamately 347 volts?
  1. How is a filter drier sized
    By kengineering in forum Technical Discussions
    Last Post: 08-08-2006, 05:00 AM
  2. Is the TEV mis sized?
    By kengineering in forum Commercial
    Last Post: 05-03-2006, 12:11 AM
  3. Need a correctly sized valve
    By Abe in forum Commercial
    Last Post: 26-10-2005, 08:42 PM
