Results 1 to 15 of 15
    sukitlek's Avatar
    sukitlek Guest
    Freezer temp. control without thermostat.
    This is my first question. I am new in HVAC and not good English. Sorry if using wrong English.
    My old freezer (More than 10 yrs) have 2 tons compressor but TXV was only 1 ton (I don't know why) running without thermostat. The temperature was controled by dual pressure controller at condensing unit. Freezer room size is around 5' x 8' x 7'.
    Now I need to change the TXV because the superheat is very high.(About 20 degree F) My question is "Can I change to 2 tons TXV?"
    Thanks,
    Sukitlek.
    Auckland
    74
    3,357
    37
    Re: Freezer temp. control without thermostat.
    More system information required, pressures and pipe run lengths. TEV are based on pressure drop across vav, for actual capacity performance, do not just read labels.
    magoo
    sukitlek's Avatar
    sukitlek Guest
    The condensing unit locate on the top of freezer then the pipe is not so long (less than 15'),
    - The pressure between receiver tank and dryer is between 300-320 psig.
    - suction of compressor is between 30-40 psig.
    - suction line temp. more than 35
    Last year the freezer worked OK about 20 F. But now temp. higher to 30 F., I cleaned TXV. (strainer and valve). During operating, Ice accumulate after TXV. at expand pipe from 1 tube to small many tube (about 3 inches after TXV.)
    Split Croatia
    57
    6,151
    36
    Quote Originally Posted by sukitlek View Post
    What refrigerant?
    How much subcooling you have at receiver outlet? Any sight glass?
    What is compressor model#?
    What is TXV model#?
    What is evaporator model#?
    Pipes dimensions and equivalent lengths.
    Height difference?
    If your freezer worked OK and now it doesn't, than some problem is developed with its operation or you changed heat load.
    MY first guess is: TXV bulb is lost its charge if subcooling is good.
    Aug 2009
    Turhona.libya
    79
    15
    Dual pressure switch is usually the control method in walk_ins freezers. There is a thermostat which controls the solenoid valve.unless i know the refrigerant you are using it's very hard to guess correctly
    Aug 2009
    Turhona.libya
    79
    15
    Dual pressure switch is usually the control method in walk_ins freezers. There is a thermostat which controls the solenoid valve.unless i know the refrigerant you are using it's very hard to make a correct guess.
    sukitlek's Avatar
    sukitlek Guest
    Thank you and Sorry for less information.
    - Compressor model is Copeland CRD1-0206-PFV-970 (Old model and equivalent to CR24KQ-PFV-980WB)
    - TXV Sporlan QE-3/8x1/2x1/4 SAE-QC-2-KT-43-VZ
    - The refrigerant is R22.
    - Ambient Temp. 75-95 F for now
    If the dual pressure switch is usually to cnotrol. I decide not change TXV to 2 tons and still change to 1 ton (The same old one). But after renew TXV. I would like to know, How much setting point the dual pressure controller, for High side, Low side and differrent setting.
    I understand that low side use for temp. control in freezer room, High side to protect the compressor and diff. pressure for how long the commpressor restart, am I right?
    Mar 2008
    232
    This is like the old days and I mean 40 plus years ago, I was with Frigidaire and most systems had only control via LP switch, even in what were then considered to be super markets.
    As an example we would set 38/42F applications to operate with a cut out pressure of 15psig and cut in at 33psig this gave off cycle defrost as well as temperature control.
    I can't help feeling that progress does not always result in better or for that matter more economical products, some times just more complicated and more expensive. The KISS principle is still in my view the best route to reliability in most products
    Split Croatia
    57
    6,151
    36
    Split Croatia
    57
    6,151
    36
    I am not aware of any CRD1 compressor with 0206 designation. It should be CRD1-0200-PFV......
    That compressor is designed for high temperature applications or air conditioning and freezer is not his intended use. He cannot go below 0°F evaporation temperature (around 20°F box temperature). His capacity is 12500 BTU/Hr at 20°F/120°F evaporation/condensing (7070 Btu/hr at 0°F/110°F evaporation/condensing).
    yI6sEOesJuPPtRjYWVFHd1I90OPICSummary.pdf
    You should stick with that TXV since it is matched to your compressor capacity at freezer temperatures.
    You could only change thermostatic element (after you prove that is faulty).
    Split Croatia
    57
    6,151
    36
    Yes, you are right.
    Settings:
    http://sporlan.jandrewschoen.com/Col...ng%20Guide.pdf
    Aug 2009
    Turhona.libya
    79
    15
    Wireless maintenance never give good results in your situation. It's better if you get the help of the one who made you learnt mechanical refrigeration
    Split Croatia
    57
    6,151
    36
    20°F for freezer is not good temperature. What goods are inside?
    sukitlek's Avatar
    sukitlek Guest
    Thank you very very... much Nike123.
    The system have no sight glass. The subcool I did not check yet cause of no good temp. measuring device.(I just the one that interest in HVAC, Not a technician just DIY and just class I hvac certificate in FL. USA., But I will purchase the temp. measuring device tomorrow with new TXV).
    - The freezer use for chicken breast and that temp.(20F) is good for slide the breast. If too cool it very hard to slide.
    Thank you again. Nike123
    Aug 2009
    UNITED STATES
    65
    Sir,
    i would go back to 1 ton txv and recheck the settings on the low pressure control
  1. Bosch Fridge Freezer Control Panel Problem
    By Bork in forum Domestic
    Last Post: 25-08-2009, 01:02 AM
  2. Ultra low Temp Freezer Design
    By jwasir in forum Fundamentals
    Last Post: 18-12-2008, 06:56 PM
  3. Hotpoint FFA71 Freezer High Temp Light / Fridge is Freezing
    By sumnerpa in forum Trouble Shooting
    Last Post: 19-08-2008, 03:16 PM
  4. Compressor loading, cooling, and range of operation.
  5. lowering freezer temp ?
    By knighty in forum Industrial
    Last Post: 18-08-2006, 06:24 PM
