Results 1 to 2 of 2
Thread: steam turbine info
21-08-2009, 04:29 PM #1
steam turbine info
Hi everyone,
My name is Todd and I recently and i recently took the written test for the NYC RMO and failed by 8 points. On the printout at the end of the test I saw that the area where I failed the most in was the steam turbine questions. I cant seem to find any books or any materials that I have that will help me with these questions. Does anybody have any place where I might find some materials that would help me with this.
21-08-2009, 04:46 PM #2
Re: steam turbine info
Hi Todd, a handy reference book for you is Steam-Plant Operation by Woodruff, Lammers and Lammers. It is probably all you will need. If you want a full blown program in power engineering then I would purchase the material from powerengineering dot org. Good luck with the next try.
Co2 vs Steam turbine power generator
By DaS Energy in forum FundamentalsReplies: 28Last Post: 28-08-2011, 09:45 AM -
Corrosion of steam condensate line
By beppo in forum Chit Chat & Service StoriesReplies: 3Last Post: 13-04-2009, 08:46 AM -
Need info on the shaft seal system for scotsman
By The MG Pony in forum CommercialReplies: 4Last Post: 17-03-2008, 02:02 AM -
Hi everyone.
By saemaru in forum Industrial CompressorsReplies: 2Last Post: 14-02-2008, 04:36 AM -
Heat Pump to drive Turbine
By Jimbo! in forum Heat PumpsReplies: 1Last Post: 13-02-2008, 12:18 AM
