    POcor's Avatar
    POcor Guest
    Samsung RL36SBMS Bottom Freezer problem
    Samsung RL36SBMS Bottom Freezer. The problem is that the fridge and freezer have stopped cooling altogether. The electricity is getting to the appliance, the light is on and a low humming noise (fan maybe motor?) can be heard. But there is no drop in temperature however long the appliance is left on.
    I have removed the back inspection panel and there seem to be almost no parts to replace - certainly no fuses I can see?
    Can u help ? What is the likely cause? Look forward to your advice. Cheers and thanks in anticipation.
    Aug 2009
    cyprus
    22
    Re: Samsung RL36SBMS Bottom Freezer problem
    Hi I don't know what kind of experience you have but you could try the fast freeze/super button.if nothing then you need to check if you have power down to the compressor & to see if it is running(it will be hot if it's working)good luck Mack.
  1. Blast freezer temperature problem. Please help!!!
    By volta in forum Technical Discussions
    Last Post: 10-05-2010, 04:54 AM
  2. Reach in Freezer Problem *Help*
    By SULTAN in forum Trouble Shooting
    Last Post: 23-08-2009, 06:25 PM
  3. Samsung problem
    By Jay(ro) in forum Air Conditioning
    Last Post: 30-07-2007, 10:40 PM
  4. Problem with freezer fan.
    By fridg in forum Fundamentals
    Last Post: 13-04-2006, 01:51 AM
