Results 1 to 2 of 2
Thread: another Samsung f/f
19-08-2009, 01:45 PM #1
another Samsung f/f
Hi guys got a Samsung RL36EBSW this one doesn't want to switch back on once it's switched off after reaching temp.the cust at the moment is just turning off & back on again.I did try the super button & the compressor fired up after a short while.Do you think it might be the fridge thermistor or a board fault.Also is it poss to put this into a diagnostic mode.Thanks Mack.
19-08-2009, 05:21 PM #2
Re: another Samsung f/f
Check to see if defrost heater is open circuit - causes shutdown if defrost is not completed
