    Aug 2009
    Malaysia
    29
    Blass chiller and compressor rack
    Hi.. I am newby and new in HVAC. Cananyone tech me what is a blast chiller and compressor rack!?
    Been hearing this.. but still could not put them into pieces what they actually do
    May 2006
    India
    74
    399
    Re: Blass chiller and compressor rack
    1) blast chiller : Chilling of products by a low temp blast of air .usually for quiuck freezing of marine products , freshly manufactured icecream etc.
    2) rack : Multiple compressors installed on a common platform , base . Advantages of rck ; you can cover vast capacity ranges by few compressors , optimal control & capabilty for high energy efficiency , back up capacity available in the event of one comp failure , easy start up characteristics .
    Aug 2009
    Malaysia
    29
    Does this means that a compressor rack system can be a blast chiller application right?
    Split Croatia
    57
    6,151
    36
    Quote Originally Posted by Kaka View Post
    Not usually!
    Mostly used in supermarket display cases applications.
    Blast chiller usually need full capacity all the time.
    Aug 2009
    Malaysia
    29
    thanks all... i hv a clearer picture now!
    Oct 2003
    5,630
    34
    Quote Originally Posted by D.D.KORANNE View Post
    And to add to this very correct description, a blast chiller can have a rack/pack as its 'compressor system'
    A blast chiller is the cold room where the products are stored and the rack or the compressor is the compressor system connected to it.
    Aug 2009
    Malaysia
    29
    Thanks everyone for explaining to me.. guess i still have alot to learn ahead of me!
