Thread: Newbie Inquiry
19-08-2009, 03:52 AM #1
Newbie Inquiry
Hi guys, I'm new in this forum... so far Im learning a lot. However, I would just like to solicit some expert and experienced opinion on my new project at hand.
I am currently in the process of putting up a cold storage facility for our business. My storage room will roughly have 30 sq. meters and 2.5 meters high (6x5x2.5) and Ill be requiring a temperature of positive 3 to positive 8 degree Celsius. The product I'm putting in is a milk beverage that is roughly at the above temp when I put it into the storage.
I have initially ask for some quotation. ASnd after which im now completely at a lost. Guys where should I start? what should I look for? What are the cooling/refrigeration equipment I need? Then there is the Hermatic or semi hermatic? Unit cooler? Help help help
Thanks in advance...
19-08-2009, 03:56 AM #2
Re: Newbie Inquiry
If I may add guys... What size, capacity of condensing (compressor0 unit and cooler unit should I look for?
19-08-2009, 09:46 AM #3
- Sep 2007
- Split Croatia
- 57
- 6,151
- 6
- 36
Re: Newbie Inquiry
http://www.heatcraftrpd.com/resource...Above32-05.pdf
Try to fill this form as much as you can and then we could help you with decisions more easily.
19-08-2009, 01:59 PM #4
Re: Newbie Inquiry
try your local fridge guy he can get his wholesaler to size up... best of luck
19-08-2009, 02:06 PM #5
Re: Newbie Inquiry
this is approx 2.5 hp condensing unit evap to match... i would go with a tried and tested scroll or lunite hermitque hermetic (cheaper) a semi is such a small job would be over kill(money wise) if you have some spare cash and want to save on running cost go with a digital scroll ......
19-08-2009, 02:34 PM #6
Re: Newbie Inquiry
I'm new here and I'm confuse! I thought you have to be certify to put this units.
19-08-2009, 02:36 PM #7
- Sep 2007
- Split Croatia
- 57
- 6,151
- 6
- 36
Newbie Practical book required
By swampthing in forum FundamentalsReplies: 6Last Post: 05-06-2008, 10:48 PM -
Hello i'm another newbie
By wkwong.alan in forum New to REReplies: 3Last Post: 16-10-2007, 03:09 PM -
Newbie
By sparrow in forum New to REReplies: 4Last Post: 13-09-2007, 11:56 AM -
Questions about NH3 from a wantabe newbie
By Minuteman in forum NH3Replies: 6Last Post: 10-04-2007, 12:46 PM
