18-08-2009, 09:54 PM #1
Daikin cassettes: any recomendations?
Hi guys,
I`m currently in the process of quoting for an installation in an office that has no false ceiling so I`m thinking of Daikin under ceiling cassette FUQ125B (the low profile 4 way throw ones). The only problem with these is that I`ll have to run trunking across the ceiling. Under ceiling fitted close to the wall might air give throw problems. Does anyone have any opinions on these before I recommend them to my customer.
Thanks in advance,
Glenn
18-08-2009, 11:13 PM #2
Re: Daikin cassettes: any recomendations?
Depending on the office style/layout/mood etc would it be feasible to camoflage the pipework inside some glossy stainless steel tubing for example.
If you make a feature of it instead of trying to hide it then sometimes it works.Brian - Newton Abbot, Devon, UK
18-08-2009, 11:17 PM #3
One thing to be aware of - if it is a low ceiling, then you will get complaints about cold draughts from the occupants.
the under ceiling cassette is good - but not for low ceilings.
19-08-2009, 12:44 AM #4
A few highwalls spread about not an option?
19-08-2009, 03:36 PM #5
I would go for underceiling one way blows all the time with a low ceilings.
Cassettes look naf, installed without a suspended ceiling.
The 4-blows are of no use as they blow the air down at about 45 degrees
19-08-2009, 07:32 PM #6
Cheers guys. After reading your comments I think I`ll go for two under ceiling ones.
Thanks again,
Glenn
19-08-2009, 11:41 PM #7
Console units not an option?
Paul
"KEEP IT COOL"
Daikin not working... many problems
By stankovicv in forum Air ConditioningReplies: 26Last Post: 11-12-2010, 09:01 AM -
Daikin, Why do we bother?
By gwilliamson in forum Air ConditioningReplies: 21Last Post: 02-02-2010, 09:38 AM -
Daikin FDYQ250M
By carl in forum Air ConditioningReplies: 7Last Post: 11-08-2009, 12:56 AM -
Daikin AC parts from UK
By skel00 in forum Air ConditioningReplies: 5Last Post: 05-04-2009, 01:24 PM -
Fixing Daikin A3 Error
By Stuffy in forum Air ConditioningReplies: 3Last Post: 27-03-2009, 06:02 AM
