Results 1 to 2 of 2
    Mar 2008
    MEXICO
    7
    Question leaking HC refrigerant in semihermetic compressor
    Hi everybody!!
    I have trouble with a semihermetic compressor (discus) that works with HC refrigerant and Polyalylenglycol. It has been reported that the refrigerant is leaked. Is it possible that sealings doesnŽt work due to the HC refrigerant or the mixture between refrigerant and lubricant?
    IŽll really appreciate your answers
    Thank you
    Mar 2005
    70
    639
    14
    Re: leaking HC refrigerant in semihermetic compressor
    You need to check with your compressor manufacturer for the materials used in the gaskets and 0-rings. Then se if they are suitable fro use with your HC refrigerant and the PAG oil.
    Ken
  1. [Autocascade] Only a project ATM
    By before in forum CPU Overclockers
    Last Post: 07-05-2009, 11:13 AM
  2. Thumping noise in the compressor
    By Husky250 in forum Air Conditioning
    Last Post: 16-05-2008, 10:48 PM
  3. Compressor Capacity
    By engrkate in forum Fundamentals
    Last Post: 13-10-2006, 12:11 AM
  4. Interesting Problem
    By NH3LVR in forum Industrial Compressors
    Last Post: 12-08-2006, 10:27 PM
  5. Starting a compressor, and receiver questions.
    Last Post: 24-08-2002, 12:37 PM
