    tansie's Avatar
    tansie Guest
    NEED HELP WITH A BEKO Model CDA 543F
    I have a lot of ice build up in the fridge, I put the automatic defrost to No. 1 as the manual says but nothing is happening and that was a few days ago, any help please
    Ashkhan's Avatar
    Ashkhan Guest
    Re: NEED HELP WITH A BEKO Model CDA 543F
    is the side by side type..american?
    Ashkhan's Avatar
    Ashkhan Guest
    is it a side by side type..if not..where or what is iceing up?
    Naami's Avatar
    Naami Guest
    is it a build up on one side of the cold plate or evenly across it?
    have you checked the door seals?
    Aug 2007
    what a peice of junk!!.......my daughters just stopped working....after much prodding with a meter it turns out the wiring between the stat and motor is open curcuit....the black wire from stat to compressor.
    ok you might think...plug at top....plug at bottom...open it up and rewire...??..NOOOOOO.........the whole thing is built as a shell...wired and then injected with expanding foam......in reality this wiring fault = a new machine...its a writeoff....not repairable.
    i have opened it up with a stanley knife and intend to rewire and refoam it....just 18 months old...junk...
  1. BEKO AP930 Flashing Error/Fault Code E8 - advice needed
    By tamba001 in forum Trouble Shooting
    Last Post: 02-11-2010, 09:28 PM
  2. Model to Manufacturer Identification
    By Lucas in forum Air Conditioning
    Last Post: 29-04-2009, 03:25 PM
  3. Fan model for system optimization
    By autt in forum System Optimization
    Last Post: 31-03-2007, 05:34 AM
  4. Daikin Model
    By Geofridgee in forum Air Conditioning
    Last Post: 12-07-2006, 09:23 AM
  5. Replies: 1
    Last Post: 30-12-2003, 03:16 PM
