13-08-2009, 02:30 AM #1
PLEASE Help with a Daikin VRV_II Compressor Phenom
I'm hoping those in the UK with more experience with Daikin than us on this side of the pond can help us. We've got a Daikin VRV_II condenser that seems to be getting hot gas back to the compressor somehow. We've replaced the 4-way valve twice. The guy that replaced it the first time didn't use a heat sync and totally melted the plastic actuator inside. We've done a proper replacement on the 4-way valve but we have to run the unit on the standard compressor only. For some reason the inverter compressor is getting a tremendous amount of hot gas back in and it gets dangerously hot very very fast. I must add that the guys who did the original install were crap and the machine has never really worked right. Can anyone offer input for the cause of this?? PLEASE HELP. Cheers.
13-08-2009, 11:12 AM #2
Re: PLEASE Help with a Daikin VRV_II Compressor Phenom
hi,vrv 2 normal cooling operation condenser solenoid valve Discharge gas pipe y5s turned off,detect pipe temperature to see if valve stuk open.the same with solenoid valve High pressure y7s turned off , detect pipe temperature to see if valve stuk open.i have same problem and found discharge mechanichal valve stuk open.change valve.good look.
18-08-2009, 02:31 AM #3
Thank you very much for the reply. I tested this out today and unfortunately the valve seems to be closed. i was hoping this would fix the issue. Thanks anyways. We're still working through it.
18-08-2009, 06:54 AM #4
Possible restricted suction strainer at the Y junction so the hot gas injection valve is energised
Daikin not working... many problems
By stankovicv in forum Air ConditioningReplies: 26Last Post: 11-12-2010, 09:01 AM -
Daikin FDYQ250M
By carl in forum Air ConditioningReplies: 7Last Post: 11-08-2009, 12:56 AM -
Daikin AC parts from UK
By skel00 in forum Air ConditioningReplies: 5Last Post: 05-04-2009, 01:24 PM -
Fixing Daikin A3 Error
By Stuffy in forum Air ConditioningReplies: 3Last Post: 27-03-2009, 06:02 AM -
Daikin Comp and inverter
By WCC73 in forum Air ConditioningReplies: 5Last Post: 08-11-2008, 08:44 PM
